Noise Removal effect
dbourgeois
Post by dbourgeois » Sun Feb 12, 2012 4:33 pm
Using the Beta version in French, I was not able to use the noise reduction feature as explained in the tutorial. I seem only to be able to take the noise profile by selecting the entire track, as oppposed to being able to select a small portion of pure noise in the track. When I select a “pure noise” portion of the track, the noise reduction effect on the menu is shadded in grey. In fact, all the effects are shaded in grey.
Can anyone help me. Sorry if I am not in the right forum.
Reason: Topic split and given more relevant title
Re: Noise Removal effect
Post by steve » Sun Feb 12, 2012 5:55 pm
To apply an effect, Audacity needs to be stopped (not in Playback, Record or Pause).
Ensure that the track that you wish to apply the effect to is selected.
To use the Noise Removal effect, the effect must have a Noise Profile before the effect can be applied.
atamo
Post by atamo » Fri Mar 02, 2012 7:09 pm
dbourgeois wrote:Using the Beta version in French, I was not able to use the noise reduction feature as explained in the tutorial. .
Unfortunately don't work neither to English version...I don't use it in Playback, Record or Pause , :arrow: I use it from long time and
IN 1.2.x version always work like a charm .
Post by steve » Sat Mar 03, 2012 1:21 pm
atamo wrote:Unfortunately don't work neither to English version...
I've tested this and I can see no problem. I must be doing something different to you.
Please give step-by step instructions for how I may reproduce the problem.
atamo
Post by atamo » Sat Mar 03, 2012 5:45 pm
In 1.3.13 release I don't have any problem but in .14release after get noise profile and mark whole track ,in step 2 nothing happening ,the noise remain....
I did everything as at previous release ...
Post by steve » Sat Mar 03, 2012 9:22 pm
What settings are you using?
