How to make Talking Tom Cat sound by Audacity?
enoch1023
Post by enoch1023 » Fri Feb 10, 2012 4:20 pm
plz help me
I need this for may homework(video production) :cry: :cry:
Re: How to make Talking Tom Cat sound by Audacity?
Post by kozikowski » Fri Feb 10, 2012 6:10 pm
You could try the Vocoder tool. That combines two sounds in a better way than just mixing. this is one example.
http://www.youtube.com/watch?v=YR_Bjf-a5rs
You put the cat sound on one side and your voice on the other.
Trebor
Post by Trebor » Fri Feb 10, 2012 9:05 pm
enoch1023
Post by enoch1023 » Sat Feb 11, 2012 5:01 am
No method by using Audacity?(like change pitch) :idea:
Post by steve » Sat Feb 11, 2012 12:19 pm
enoch1023 wrote:No method by using Audacity?(like change pitch) :idea:
Try it.
Effect menu > Change Pitch.
enoch1023
Post by enoch1023 » Sat Feb 11, 2012 3:33 pm
Try it.
change to which %
Post by steve » Sat Feb 11, 2012 3:45 pm
enoch1023 wrote: change to which %
What % did you try?
What happened when you did that?
If you don't get the result that you want, you can "undo" the effect by selecting "Undo" from the Edit menu.
whbjr
Post by whbjr » Sat Feb 11, 2012 8:33 pm
enoch1023 wrote:
Try it.
change to which %
Just as a starting point, I tried 40% (about the same as 6 semitones up), and the results were pretty similar to Talking Tom. Now I just have to practice my purring sound...
enoch1023
Post by enoch1023 » Sun Feb 12, 2012 2:27 pm
whbjr wrote:
enoch1023 wrote:
Try it.
change to which %
Thx,40%!!
