Windows 7 OS
mailhot
Windows 7 OS
Post by mailhot » Fri Feb 10, 2012 2:23 am
Hi need help pleasee.
My Win 7 OS HDD only has 9 GB free out of 50GB and the 1.3 version loaded on this drive and not the one with 500 GB. All the x86 OS Program Files files are on here and I only have 7.5 hours or recording time...what should I do?
Thanks in advance...
Marc :roll:
ragnar.jensen
Re: Windows 7 OS
Post by ragnar.jensen » Fri Feb 10, 2012 5:33 pm
Create a directory on the large drive.
Edit -> Preferences -> Directories
Preferences dialog
Set the Temporary files directory to the directory you just created on the larger drive.
Ragnar
Re: Windows 7 OS
Post by steve » Fri Feb 10, 2012 6:02 pm
In addition to the advice given by ragnar.jensen,
Once an Audacity Project has been saved, all further temporary files will be saved in the Project _data folder.
If you're unsure what a "Project _data folder" is, see here: http://manual.audacityteam.org/man/Audacity_Projects
mailhot
Re: Windows 7 OS
Post by mailhot » Sat Feb 11, 2012 2:04 am
Creating a new directory did the trick...thanks to those who helped me here...appreciate it!
Marc :)
