ccernst wrote:Using my workstation (win7, 1.3.14, lame 3.98.3), I can successfully create MP3s using the project recorded using the recorder machine(xp sp3, 1.3.14). Using my workstation (win7, 1.3.14, lame 3.98.3), if I go back and try to export/create MP3s using the project created when the recorder machine was running 1.3.11, the MP3s do not export correctly and flatlines just before 1:30. I've tried both from the external USB Drive and internal hard drive.
I've uploaded my project file from version 1.3.11 to Minus, anyone can have a look if they'd like. In the zip file, you'll have the project as well as the first track that was corrupted.
OK, thanks. The old Audacity bug I had in mind which could possibly have been responsible would not be in 1.3.11.
As your experiment confirms, I would doubt lame_enc.dll is responsible for what you have seen in past exports. I also doubt loss of saved data or faulty network transmission is responsible (the data is not silenced).
Please let us know if you have any more problems (using 1.3.14). If bad recorded data which gets negatived on processing is the issue, it may be possible to copy part of the track from the current project to a new project, so make a small enough project to post somewhere.
kozikowski wrote:I'm not talking about a laptop battery. The CMOS battery is the little watch battery on the motherboard that keeps the clock and computer configuration in memory while the computer is off. The clock being consistently off is a major danger signal. If the battery goes far enough down, it will kill the system configs and the machine will stop dead.
A bad laptop battery can cause the system clock to be behind even with a new CMOS battery, and if the laptop battery is weak it may not charge the CMOS battery properly. I'd say you want to look first at the laptop battery and then the CMOS battery if the clock problems are not corrected ( here is
some help changing the CMOS battery for anyone that needs it).
kozikowski wrote:
There are known problems with editing of any sort, video or audio on USB drives. They have wonderful specifications, just not all at once. They're half-duplex. They go one direction only, then they reverse and go the other way. If your software isn't aware of that, you could get holes in the work or outright failures. It's not FireWire which is full duplex. It's a very similar problem with editing over a network. If your software is not aware of network delays, collisions and retries, it fails.
I don't know if you have bad experiences to quote but I would be fairly confident in working with Audacity projects on a USB 2.0 drive. I do so myself sometimes (they are all very long projects of 3 hours or more which is why they are on an external drive). There are no playback issues. I would not recommend working with projects over a wired or wireless network unless you have gigabit ethernet.
