kozikowski wrote:I'm not talking about a laptop battery. The CMOS battery is the little watch battery on the motherboard that keeps the clock and computer configuration in memory while the computer is off. The clock being consistently off is a major danger signal. If the battery goes far enough down, it will kill the system configs and the machine will stop dead. So you're complaining about unstable software on a known unstable computer.
There are known problems with editing of any sort, video or audio on USB drives. They have wonderful specifications, just not all at once. They're half-duplex. They go one direction only, then they reverse and go the other way. If your software isn't aware of that, you could get holes in the work or outright failures. It's not FireWire which is full duplex. It's a very similar problem with editing over a network. If your software is not aware of network delays, collisions and retries, it fails.
Koz, not going to argue this point much, but I've been building machines quite some time. I know exactly the battery you are talking about. All it does is save bios configs. I'll say this, I know my bios is set to factory default settings except for time, FSB, and Clock Multiplier (AMD Athlon XP unlocked)...those are the only settings changed. So when the battery goes dead and the machine has been off for a while, my motherboard loses time, FSB goes to 100, and Clock Multiplier defaults down to 8x. I do not bother with time and I simply ramp the FSB back to 133 and the clock multiplier to 13...very stable at that speed...it'll run Prime95 torture test all day. The only thing time should matter to recordings would be the timestamp put on the files created.
Using my workstation (win7, 1.3.14, lame 3.98.3), I can successfully create MP3s using the project recorded using the recorder machine(xp sp3, 1.3.14).
Using my workstation (win7, 1.3.14, lame 3.98.3), if I go back and try to export/create MP3s using the project created when the recorder machine was running 1.3.11, the MP3s do not export correctly and flatlines just before 1:30. I've tried both from the external USB Drive and internal hard drive.
I've uploaded my project file from version 1.3.11 to Minus, anyone can have a look if they'd like. In the zip file, you'll have the project as well as the first track that was corrupted.
http://min.us/mbo9Q3tP5V
