build a context menu
Audio software developers forum.
Bquentin
Re: build a context menu
Post by Bquentin » Wed Apr 04, 2012 2:45 pm
Thanks per advance !
Quentin
Post by steve » Thu Apr 05, 2012 2:42 am
Very interesting.
The pop-up menu on Right Click works some of the time.
It builds OK but there's a warning during "make":
Code: Select all
TrackPanel.cpp: In member function ‘virtual bool TrackPanel::HandleTrackLocationMouseEvent(WaveTrack*, wxRect&, wxMouseEvent&)’:
TrackPanel.cpp:5018: warning: unused variable ‘bResult’
A couple of small issues:
1) For English keyboards the shortcut for "Redo" should be shift + Ctrl +Z
2) The keyboard shortcut for Play and Stop is the spacebar (Space), but as shown in the screenshot these are not listed.
3) Sometimes the pop-up does not pop-up (though if I use "left click" and then re-try the right-click it may pop up).
A more serious problem is that sometimes mouse clicks stops working altogether (left click and right click). I can't help with that one.
I'd imagine that some users would find this feature useful, though personally I don't think that I would use it as all of the actions are easily accomplished from the keyboard.
Making use of right click is quite a common request, but I don't think that everyone agrees about what right click should be used for.
As a "proof of concept" this certainly works.
Bquentin
Post by Bquentin » Thu Apr 05, 2012 10:31 am
Thanks for spending times to try my patch, and your comments. it will help me.
Quentin.
