Putting 2 clips together
Cherrykisses96
Post by Cherrykisses96 » Mon Jan 23, 2012 5:01 pm
Hi i was wondering if someone could tell me how to put the short clips together without them over lapping or fading? Thank you :)
Re: Putting 2 clips together
Post by steve » Mon Jan 23, 2012 7:21 pm
Import your audio clips - they will appear in tracks one above the other. Then use the Time Shift tool to slide one of the clips to the right so that one follows on from the other like this:
When you Export (File menu > Export > Audio) the tracks will be combined (mixed) into a single track
