g verb
suttlemyre
g verb
This was the quick fix option under G verb. I think this is a lil too much on the vocals. Which setting doyou suggest to lower? thanks james
- Attachments
- sample.mp3
- (224.13 KiB) Downloaded 392 times
Re: g verb
I'd probably reduce the Reverb time to perhaps around 2 seconds.
I prefer to use the "Duplicate and mix together" method as that allows you to listen to the track while adjusting the Wet/Dry mix. If using this method, try these settings:
Roomsize: 40 m²
Reverb time: 2 s
Damping: 0.9
Input bandwidth: 0.75
Dry signal level: -70 dB
Early reflection level: -14 dB
Tail level: -21 dB
then adjust the track "Gain" slider for the GVerb track down to around -6 dB. The Gain slider can be adjusted while playing and listening to the track.
Roomsize: 40 m²
Reverb time: 2 s
Damping: 0.9
Tail level: -21 dB
suttlemyre
Re: g verb
got it thanks
