Help Audio editing only possible in 1 sec increments only??
extendmedsupport
Post by extendmedsupport » Fri Jan 20, 2012 4:23 pm
I'm trying to edit audio and Audacity is allowing me only to edit in one second increments. I can't place my cursor in a desired location in order to do any editing. I tried uninstalling the version of audacity I was running 1.3.13. Once uninstalled I downloaded the most up to date version (1.3.14) thinking this would solve the problem, no luck. How do I disable this mode I seem to be in? Please help...
I'm running Windows 7.
Thank you!!!!
billw58
Re: Help Audio editing only possible in 1 sec increments onl
Post by billw58 » Fri Jan 20, 2012 4:25 pm
Uncheck "Snap To" in the selection toolbar at the bottom left of the project window.
http://manual.audacityteam.org/man/Selection_Toolbar
-- Bill
extendmedsupport
Post by extendmedsupport » Fri Jan 20, 2012 5:57 pm
Well that was easy enough. Thanks so much Bill!
