Audio Format
Sly
Audio Format
Post by Sly » Fri Sep 12, 2008 5:13 pm
Is it possible to record audio in the following format?
PCM 8KHZ, 16 bit, Mono
We have a program that specifically needs this audio format as it is used over normal telephone lines?
Re: Audio Format
Post by steve » Fri Sep 12, 2008 5:19 pm
Yes
Look in
"Edit > Preferences > Audio I/O"
and
"Edit > Preferences > Quality"
to set the defaults.
Note that in Audacity 1.3.5 you can record in any format, then select your destination format when you Export your finished project.
Sly
Re: Audio Format
Post by Sly » Fri Sep 12, 2008 5:47 pm
Thanks for the Quick reply. Will give it a shot.
