hacked sound?
sorman
hacked sound?
Post by sorman » Thu Jan 19, 2012 11:23 pm
Hi.
I am new to audacity and it seams like a verry good software.
BUT.
Sometimes it sounds good and sometimes it sounds bad when i record.
listen to the bad, attached.
why?
Tryed allot in my settings, but no go!
Test.mp3
(143.67 KiB) Downloaded 57 times
Re: hacked sound?
Post by steve » Fri Jan 20, 2012 2:24 am
You're using some sort of USB audio device?
sorman
Re: hacked sound?
Post by sorman » Fri Jan 20, 2012 2:39 am
No I am yousing what yuo here.
Re: hacked sound?
Post by steve » Fri Jan 20, 2012 4:04 am
sorman wrote:No I am yousing what yuo here.
You mean that you are using the "What U Hear" option for the internal sound card in your computer?
If you have a microphone plugged into your computer sound card, use the Device Toolbar to select the "Mic In" option as the recording device.
The "juddery" sound is because some part of your computer is unable to keep up with the amount of data from the sound card that needs to be written to the hard drive.
First, try setting the recording device as just described. If the problem persists you'll need to work through the suggestions on these pages:
http://wiki.audacityteam.org/wiki/Troub ... ings#Skips
http://wiki.audacityteam.org/wiki/Manag ... nd_Drivers
