Hello, I have a Fostex VF16 digital mutlitrack recorder recording 7 instrument tracks of a band, each is a mono track.
I have Audacity 1.3.13-beta running on XP sp3 using a PCI soundcard accepting S/PDIF lightpipe i/p.
At the moment I’m transferring the 7 tracks individually by means of S/PDIF and lightpipe, saving each as a .wav file & opening them as multiple tracks into an Audacity window.
I can lock them together using ‘sync lock tracks’& time shift each track with the ‘time shift tool’, but they are not properly in sync.
Q. How do I get all 7 tracks to be automatically in sync for editing in Audacity?
I imagine I’m importing a time code with each .wav file, but how to sync them?
Export as a stereo pair, after mixing.
New to mixing so any help would be appreciated – Thank you.
multi track sync
martinsnow
Re: multi track sync
Unless your system explicitly says so, I wouldn't assume that. SMPTE time code and other video services are special beasts with intentional provision for burned-in running time or time of day. That's not normal in straight audio land. SMPTE time code, for one example, is one whole audio track itself.I imagine I’m importing a time code with each .wav file,
What's improper about them? The movie people use a clapboard...they are not properly in sync.
http://www.studio1productions.com/clapboards.htm
At the beginning of every shot so the picture and sound people can easily re-sync themselves in post production.
