unable to open some files
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
rotempick
Post by rotempick » Fri Sep 12, 2008 12:10 am
When I try to open some of my audacity files
I get the following massage "not well formed on line 3".
What can I do?
Re: unable to open some files
Post by steve » Fri Sep 12, 2008 2:39 pm
I'm not sure what you mean. This is the "Downloading and Failed Installation Issues" board. Are you having a problem downloading or installing Audacity? If it is a problem using Audacity, please post on the Windows, Mac or Linux board for the version of Audacity that you are using (that will save us having to ask you what your operating system is).
Also, please give as much information about the problem as you can - in fault finding, too much info is better than not enough.
rotempick
Post by rotempick » Mon Sep 15, 2008 12:22 pm
My problem is naw fixed.
I saved my files in HEBREW, there for I couldn't open them properly.
When I changed the file name, also the data file, and the name inside the code back to ENGLISH, I was able to open the files, thank you and sorry for posting in the wrong section.
