Cannot export to My Music
braavo
Post by braavo » Tue Jan 10, 2012 10:50 pm
Moderator note - new topic started with appropriate title. Please do not post to old topics unless you have a completely relevant comment that throws new light on that specific topic.
I have 1.3.14 with win XP. I need step by step on saveing the recording. It is saved in recent files, but can't export it to My music or music maker. Everytime I find it in a file, it says already open in another file.
Kenny
Re: Cannot export to My Music
Post by steve » Wed Jan 11, 2012 7:00 pm
braavo wrote:Everytime I find it in a file,
What does that mean?
Post by Gale Andrews » Thu Jan 12, 2012 4:13 am
That sounds like trying to open an Audacity project that is already open in another window.
What 1.3 version of Audacity are you using (see Help > About Audacity). Is it 1.3.14, 1.3.13, or what number after the "1.3."?
What format are you trying to export to - WAV, MP3? To export MP3 you need to add LAME to your computer following these instructions:
http://audacityteam.org/help/faq?s=install&i=lame-mp3 .
If you still get an error using File > Export, what does the error say? Does it say you might be out of disk space?
braavo
Post by braavo » Fri Jan 13, 2012 9:22 pm
Am using 1.3.14 with win XP. I need to export the music files as wav into a location such as MY MUSIC or whatever would be appriate. Then I could bring up that file for effects or burning. I would like a step by step from getting the recording to the burn cd action. I cannot find these exact steps in a tutorial. Do I need to name a project before I record? This probably sounds elementry but I would really appreciate some help.
Post by steve » Fri Jan 13, 2012 9:48 pm
braavo wrote:I would like a step by step from getting the recording to the burn cd action.
So you have accomplished the recording step successfully?
See tutorials 4 and 5 here: http://manual.audacityteam.org/man/Tuto ... iscs_to_CD
braavo
Post by braavo » Sat Jan 14, 2012 4:15 pm
Recording is good. The tutorials is no help. I need precise steps pertaining to "save as and save to'" do that I cn locate the file at a latter time.
Post by steve » Sat Jan 14, 2012 4:46 pm
braavo wrote:Recording is good. The tutorials is no help. I need precise steps pertaining to "save as and save to'" do that I cn locate the file at a latter time.
See here: http://forum.audacityteam.org/viewtopic ... 77#p167798
braavo
Post by braavo » Mon Feb 20, 2012 11:06 pm
OS is winfows XP Audacuty 1.3.14
I need more help.
Export to screen is open
Save in My Music
Save as type WAV 16 bit
File name tune A
The only option is save
I click save
tune A appears under my music. I right click on this file. I click opoen in the dropdown box.
I get the message that this file already exists, do I want to replace it.
I click my computer>my music, tune A is not there
What is the problem?
braavo
Post by steve » Tue Feb 21, 2012 1:06 am
What happens if you Export a WAV file to your Desktop?
Post by Gale Andrews » Tue Feb 21, 2012 1:17 am
braavo wrote:OS is winfows XP Audacuty 1.3.14
I need more help.
Save in My Music
File name tune A
I click save
in what program does the file appear where you right-click on it? In Windows Explorer?
braavo wrote:I click opoen in the dropdown box.
Is this in Audacity, if so in File > Open or File > Import > Audio?
braavo wrote:I get the message that this file already exists, do I want to replace it.
You would only get a message about a WAV file existing if you were exporting it. Is that what you were doing there?
braavo wrote:I click my computer>my music, tune A is not there
Is this after exporting the WAV and agreeing to replace it? Did you see any error in Audacity when you tried to export it?
You know that in Windows the file name will say only "Tune A", not "Tune A.WAV?
