When I auto tune my voice it auto tunes my instrumental?
ineedhelpguys
Post by ineedhelpguys » Mon Jan 09, 2012 10:50 pm
I record my voice in audacity. And I autotune it with autotune evo est and then I add my instrumental.
So when I add it, my voice and my instrumental gets autotuned so when I play the whole thing it sounds messed up.
How do I just autotune my VOICE and keep the instrumental playing but not have it be autotuned.
Help?
Re: When I auto tune my voice it auto tunes my instrumental?
Post by steve » Mon Jan 09, 2012 11:05 pm
Audacity 1.2 does not support Autotune.
ineedhelpguys wrote:And I autotune it with autotune evo est and then I add my instrumental.
So you are using Autotune before you add the instrumental and you don't use Autotune after you have added the instrumental?
If that is the case then I don't see how Autotune can possibly affect the instrumental. :?
What exactly are you using and what exactly are you doing?
ineedhelpguys
Post by ineedhelpguys » Mon Jan 09, 2012 11:12 pm
I'm using audacity 1.3 and I recorded my singing voice.
I used autotune evo est to autotune my voice.
I also added the instrumental to the song I was singing so I could mash them together.
But when I autotune my voice it also autotunes the instrumental track and that makes it sound really bad.
I'm trying to just autotune my VOICE and not the INSTRUMENTAL
Here's a pic:
http://imageshack.us/photo/my-images/35/picbv.png/
When I autotune it using autotune evo est it makes both tracks autotuned and it sounds messsed up.
How do I just do it for my voice?
Post by steve » Tue Jan 10, 2012 12:21 am
Topic moved to the Audacity 1.3.x forum.
ineedhelpguys wrote:when I autotune my voice it also autotunes the instrumental track and that makes it sound really bad.
Double click on the vocal track - that will select the vocal track and it will be highlighted.
Apply the effect - only the selected track will be affected.
See hear to learn more about "selections": http://manual.audacityteam.org/man/Audacity_Selection
ineedhelpguys
Post by ineedhelpguys » Tue Jan 10, 2012 12:27 am
I did that but it's still autotuned..
What am I doing wrong?
Post by steve » Tue Jan 10, 2012 12:37 am
As a test, try using some different effect - something with a really strong and noticeable impact, for example the "Fade-In" effect. Are you able to apply that to one track only and not the other?
Post by kozikowski » Tue Jan 10, 2012 1:03 am
Can you press "mute" on the music track (to the left) and play your voice track only?
