Need Saved Recording Help
Lawrie
Post by Lawrie » Mon Jan 09, 2012 4:09 pm
Hi,
I use Audacity to record backing tracks. It works great but on occasion, the curser won't set to zero when I open a saved track. Here's an example:
How do I get the curser to open at the zero mark?
Thanks in advance,
Lawrie
Re: Need Saved Recording Help
Post by kozikowski » Mon Jan 09, 2012 5:33 pm
If you Saved a Project with a segment selected, then that's how it's going to open next time. Select the top track by clicking in the sound specification window at left and press Home -- or it may just go home by itself.
Lawrie
Post by Lawrie » Mon Jan 09, 2012 5:57 pm
kozikowski wrote:If you Saved a Project with a segment selected, then that's how it's going to open next time. Select the top track by clicking in the sound specification window at left and press Home -- or it may just go home by itself.
That seemed to work, thanks.
