Can't record sound internally
Vince5535
Post by Vince5535 » Mon Jan 09, 2012 6:35 am
This question may have been asked many times, but I can't remember how to record sounds coming from the computer. I did once before on the same computer but i reformatted my computer a couple months ago. I have found the stereo mix and everything easily yet im not sure if I have my inputs and outputs right on Audacity or what.
waxcylinder
Re: Can't record sound internally
Post by waxcylinder » Mon Jan 09, 2012 10:25 am
see this tutorial from the 1.3 manual: http://manual.audacityteam.org/man/Tuto ... e_computer
Vince5535
Post by Vince5535 » Tue Jan 10, 2012 1:56 am
Thank you, but I tried the set up, checked my drivers, and and still doesnt work. Im not sure what Im doing wrong
Post by steve » Tue Jan 10, 2012 8:20 am
Which version of Windows?
Vince5535
Post by Vince5535 » Wed Jan 11, 2012 12:22 am
Windows 7 sir, do u guys need a sandra report or anything. its funny I had it working before i reformatted my computer.
Post by steve » Wed Jan 11, 2012 12:48 am
Vince5535 wrote: do u guys need a sandra report or anything.
No, but we do need a clear picture of what equipment you are using and what you are doing and what the problem is.
Vince5535 wrote: I have found the stereo mix and everything easily yet im not sure if I have my inputs and outputs right on Audacity or what.
Vince5535 wrote:Thank you, but I tried the set up, checked my drivers, and and still doesnt work. Im not sure what Im doing wrong
What exactly is the problem? We know that it's "not working" but what part are you having trouble with? waxcylinder sent you a link to the instructions - where are you getting stuck?
Vince5535
Post by Vince5535 » Wed Jan 11, 2012 5:46 am
Lets see... Step One, found the stereo mix in my recordings part of the control panel, I have it as the default with all other devices turned off and I have it set in the recording slot on audacity. On Audacity it is titled Stereo Mix Realtek Definition High Audio. Im not sure if the playback device is the prob as i tried all the playback setting while the recording was on stereo.
Step Two, Software playoff is off of course
Step Three, I set the monitoring to On, not getting a reading from it though
Step Four, Guess ill stop here since the waves are not showing.
Far as Equipment i do have an Avid mbox hooked up but i did turn it off along with the section it was located in under the recording tab. I have a HD webcam which I also turned off. I doubt my monitors will affect it as they are in the playback tab.
Mybad I know its a hassle with some people with tech difficulties and i do apologize in advance
Post by steve » Wed Jan 11, 2012 6:25 pm
Vince5535 wrote: I doubt my monitors will affect it as they are in the playback tab.
USB speakers?
You've not said what you are trying to record. What are you trying to record?
The playback device is important. "Stereo Mix" tells the sound card to use its own output as the recording source. If your computer is playing sounds through USB speakers, then it is not playing through the sound card and so there will be no output from the sound card, so nothing to record.
Vince5535
Post by Vince5535 » Thu Jan 12, 2012 5:35 am
Just some music off the net basically since i can find it on youtube, well i turned off my monitors in the playback section and now I just have the realtek digital output as the playback source but no response though
Post by steve » Thu Jan 12, 2012 4:59 pm
What are the available options for the playback device in the Device Toolbar?
