When is Inverse RIAA appropriate?
LDMartin1959
Re: When is Inverse RIAA appropriate?
Post by LDMartin1959 » Sun Jan 08, 2012 11:27 pm
waxcylinder wrote:DC offset (if you have it) is a result of a faulty or poor soundcard, a small (sometimes large DC current) is appled to the signal, sometimes just one of the channels. It shows up visually as a waveform that is not centred on the zero centre line.
Is there a way to test for the presence of the DC offset? I presume that be testing one can determine the exact amount and improve the adjustment setting?
Thank you.
billw58
Post by billw58 » Sun Jan 08, 2012 11:53 pm
LDMartin1959 wrote: Is there a way to test for the presence of the DC offset? I presume that be testing one can determine the exact amount and improve the adjustment setting?
The "Remove DC Offset" option in the Normalize effect calculates the required correction.
If you want to see if you have DC offset, record with no signal (but your equipment connected), then zoom vertically to maximum. If the signal is not centred on the zero line then you have DC offset.
http://manual.audacityteam.org/man/Zooming#vertical
-- Bill
LDMartin1959
Post by LDMartin1959 » Mon Jan 09, 2012 12:31 am
billw58 wrote:If you want to see if you have DC offset, record with no signal (but your equipment connected), then zoom vertically to maximum. If the signal is not centred on the zero line then you have DC offset.
Got it. Thanks.
