I'm having problems to use the effect Equalization while using the preview function.
The first time i change the equalization graphic and press preview, it works without problem.
If i press again to preview it uses a flat equalization regardless the changes i've made. That's all i have to report... Thank you.
Problems with Equalization preview...
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
Re: Problems with Equalization preview...
Yes, this is a known problem. It has now been fixed in the latest development version, so you may well want to upgrade to 1.3.6 when it is released (keep an eye on the main Audacity web site download page).
How do I equalize a short space of audio that is muffled?
You may be able to make it sound less muffled by turning up the higher frequencies (take care that you do not make the sound so loud that it distorts - if the waveform hits the top or bottom of the track it will distort. To avoid that problem you can use the Amplify effect to reduce the level before using the Equalizer.
Whether this works or not depends on why it sounds muffled. If the high frequencies are missing, no amount of boost will bring them back.
