Labels and export multiple not working correctly [SOLVED]
mmb
Post by mmb » Sat Dec 31, 2011 5:44 pm
I use to Audacity to transfer some old concert recordings - I record and then split into tracks - when I checked the labels using edit labels I notice that the start time and end time of each track is the same i.e start time 00 h 07 m 19 s end time 00 h 07 m 19 s - I useD 1.3.14 beta and after discovering the problem reverted back to 1.3.13 beta but the problem remains.
Screenshot of tracks
tracks split.jpg (124.28 KiB) Viewed 462 times
billw58
Re: Labels and export multiple not working correctly
Post by billw58 » Sat Dec 31, 2011 6:04 pm
You do not have a problem. You are using point labels to mark the start of each song.
See: http://manual.audacityteam.org/man/Export_Multiple
and: http://manual.audacityteam.org/man/Spli ... ate_tracks
-- Bill
mmb
Re: Labels and export multiple not working correctly [SOLVED
Post by mmb » Sat Dec 31, 2011 6:40 pm
okay thanks
