Dear Audacity people,
I have an 8th grade science project were I'm recording different combinations of picks and strings(of different materials) being used on a guitar with Audacity. I need to determine which combination has the most volume and clarity. I'm planning to use a decibel format to represent the volume of each strum. There are a lot of numbers and decibels, so I was wondering...how can I find the maximum decibel volume of each recording?
Thanks for your time. -Nikki
Science Project Help
nikkiscruz
Re: Science Project Help
You can't do "clarity," but you can do volume pretty easily. You can use an expanded version of the volume meters.
Click on the right edge of the sound meters and pull to the right. They will get larger and much easier to see.
http://kozco.com/tech/audacity/Audacity1_playback.jpg
You can even undock them and make them larger still.
http://kozco.com/tech/audacity/Audacity1_full.jpg
Those meter peaks are the digital volume values.
How are you going to control for strum? I can make any guitar string sound louder and softer by strumming harder. Also as with any instrument like this, the attack of the note is very loud and non-musical. If you try to analyze it, you will just see noise. So then you get to decide where in the note decay you wish to measure.
You might be able to do clarity with Analyze > Spectrum. This is an analysis of one piano note. G two octaves down, I think.
http://kozco.com/tech/audacity/piano_G1.jpg
So that's G1, not quite falling off the end of the keyboard. Everything to the right of that very high peak is harmonics and overtones which determine note "quality." You could make a case that the more overtones, the "clearer" the note. It's not strictly true. It can stay the same clarity and just get "richer" and "fuller."
Sounds much like this project: http://forum.audacityteam.org/viewtopic ... 13&t=53280nikkiscruz wrote:I have an 8th grade science project
nikkiscruz
Thanks, I figured it out. I made a machine that strums the guitar the same every time. -nikki
