Audacity Auto-Corrects Sound Input
Sound_Student
Post by Sound_Student » Mon Dec 26, 2011 6:59 pm
Hi everyone.
I downloaded Audacity off of a recommendation to use as a recording and analysis platform for a project I am doing. To get familiar with the process, I was recording the sound of car engines at various RPMs. While doing this, I noticed that for the first second, the sound levels would be much higher then would drop off. This difference could be noticed during playback. It seemed that Audacity was correcting at least the volume of the sound; for the project, I am trying to analyze the sound itself, and can not have any corrections.
This is the window for the 3500 RPM test. The sound seems to change as recording goes on, going from a large pattern to a much smaller one. I would think this would be the car itself, but the same pattern was observed again:
when the car was measured at 2500 RPM. I was wondering if anyone knew how to turn off this process so as to record the sound unaltered.
Thank you,
Sound_Student
Re: Audacity Auto-Corrects Sound Input
Post by kozikowski » Mon Dec 26, 2011 7:21 pm
Audacity isn't doing that. That's a Windows problem. Windows comes out of the box as a corporate internet communications device (Skype, Vidyo, Windows Meeting), etc., Not an entertainment recorder. You are experiencing Echo Cancellation or Auto Level Control.
-- Windows Conferencing Services
http://forum.audacityteam.org/viewtopic ... 79&start=0
http://manual.audacityteam.org/man/FAQ: ... hancements
Skype has their own, so you might not want those services anyway.
Sound_Student
Post by Sound_Student » Mon Dec 26, 2011 8:06 pm
Thank you. I applied the fixes and while it has worked, the sound volume levels are much lower than they were before. Any ideas?
Sound_Student
Post by Sound_Student » Tue Dec 27, 2011 8:16 pm
Ok, I disabled all the sound effects and recorded the engines. However, when I used the "Plot Spectrum" tool to plot the frequencies, everything came out the same. Any sound I took had the same frequency, just with different decibel levels. Is this to be expected or is there something wrong that is changing the recording? When I turned on the Acoustic Echo Cancellation and recorded again, the spectrum analysis came up with many more frequencies. Why is this happening?
