I installed the Beta version in a netbook with Windows 7 32 bit after following al the instructions provided with the device. After installing the SW, I plugged the device to USB port. Windows pop up message says that it was unable to recognize the device. How do I get an update driver for Tape2USB that is compatible with Windows 7.
Here is the driver version that your SW installed in my machive:6.1.7601.17586
Is this device compatible with Windows 7 OS 32 bits?
I would appreciate your assistance
Thanks
1.3.14-beta WINDOWS 7 32 bit does not recognize USB port
Re: 1.3.14-beta WINDOWS 7 32 bit does not recognize USB port
We'd be Googling. It seems the device is discontinued. You could call them or dig in their web site for legacy drivers.How do I get an update driver for Tape2USB that is compatible with Windows 7.
I'm surprised that Windows couldn't find it. Playing a cassette tape into a computer is not rocket surgery. The standard, unexciting USB drivers for a generic sound device should do it.
Unless your device is broken.
Can you try it on another computer?
Just going on some of the comments posted on the forum, I got the impression that the generic USB drivers would be enough. Try rebooting your computer and see if the problem persists.
