Staying in rhythm when creating loops, editing
Trebor
Re: Staying in rhythm when creating loops, editing
Post by Trebor » Mon Jan 02, 2012 4:47 am
loopman wrote:Anyway, have a listen, I think it's pretty groovey....
shalamarloop.wav
It’s good, but a loop should start and end on the same value, usually zero ...
shalimar loop starts and ends on zero.png (22.29 KiB) Viewed 566 times
[for the uninitiated Audacity will loop if you press shift + play ]
Shali-More.mp3
(743.67 KiB) Downloaded 94 times
VenusAndMars
Post by VenusAndMars » Tue Jan 03, 2012 11:23 am
loopman wrote:Man, I'd use that sample in HammerHead, crank it up to 160 bpm and throw
down some serious techno....
HammerHead eh? Hmm...I'll give that a try if there is a trial. Your Shalamar loop sounds great. In the pocket!
loopman
Return to Raverhurst
Post by loopman » Tue Jan 03, 2012 10:42 pm
Allright, just one more example on this topic.
This, again, is what I call a "in-track loop".
That is, I haven't taken the loop out and applied fade-outs, just selected the
audio and used the command: effect | repeat
In this particular example, the original "loop" by the original composer runs some
three measures (or bars), before the orchestra repeats with the same notes.
In the picture, this is denoted by the loop "01" and loop "02" regions.
The editors of this audio have allowed the piece to run for 3 measures, then
2 measures more (loop 02), before truncating it at the start of the 3rd measure
of "loop 02" (the unique pattern part).
You COULD create a loop from this audio using just the audio found in the "loop 01
section" as it is "all there" (just not shown in the picture), but in this example, the
Loop 01 section's first two measures are a bit "dainty".
So, what I did was loop from:
06.448354-11.176530
...thus, the first part of the second loop is now the end of the NEW loop, but it all
works anyways and even manages to sound authentic.
Here's the example, have some fun...
looping-example001.mp3
(271.84 KiB) Downloaded 65 times
VenusAndMars
Post by VenusAndMars » Wed Jan 04, 2012 6:28 pm
So is it a gamer you are loopman? I just couldn't figure out the meter of your clip/loop. It sounded like 6/4 superimposed on 4/4 or somesuch, two rhythms running simultaneously. But good.
Btw thanks for introducing me, sort of, to HammerHead rythm station. It's great good fun, easy to get going with, and one sounds suspiciously good with minimum input right from the start. :)
