rite,i have had audacity for about a month.i love it!but it seems that every time i try recording from my mic it doesnt play the sound as well as recording?!?!?!i mean its a major problem because im tryin to record for raps and stuff and im totally out of tune!
please help!
recording problem
gangsta tricky
Re: recording problem
You need to have perfect pitch to use the Audacity vocal recording function.
Just kidding.
Audacity > Preferences > Audio I/O
Juggle between Software Playthrough and Hardware playthrough. Pick the one that's least objectionable. Some don't work and some play to your headphones late. Depends on the machine.
Just kidding.
C'mon koz - don't confuse the poor chapkozikowski wrote:You need to have perfect pitch to use the Audacity vocal recording function.
Just kidding.
On Windows, it is highly recommended to NOT use "software playthrough" unless absolutely essential - it causes real bad echo delay. On Windows, "hardware playthrough" is not a selectable option - it is automatically set for hardware by default.kozikowski wrote:Juggle between Software Playthrough and Hardware playthrough.
"play other tracks while recording new one" should usually be selected.
