Is it possible to simultaneously record and playback?
Lunik
Post by Lunik » Wed Dec 14, 2011 11:53 pm
Hi, I have a small question about the capabilities of Audacity.
Basically, I was wondering whether or not it was possible to have audacity playback a recorded track while at the same time recording a new one. I'm curious because I'm having trouble getting multiple tracks to be syncronized with each other when recording them in different sittings.
Thanks!
Re: Is it possible to simultaneously record and playback?
Post by kozikowski » Thu Dec 15, 2011 12:25 am
Yes, no problem in Audacity 1.3, but it may not be possible to perfectly make the computer do it.
Which delay have you got? The one where you sing in perfect time but it plays out of time is easy. That one's Recording Latency, and it's a setting in Audacity 1.3.
If you expect to hear yourself in your headphones in perfect time with your lips, that one is very serious.
Tell us exactly what you're doing and I'll see if there is a document that applies. I've written several pieces reflecting various ways to do it. They're in final editing.
It's called Multitrack/Overdubbing. Playing one song and adding parts to it over and over again.
I'm shooting for "The Andrews Brothers." Three part harmony.
Lunik
Post by Lunik » Sat Dec 17, 2011 1:19 am
Well, just in general, how would you do it? When I press the play button the record button is greyed out, and vice versa. And I can't hit the "play" and "record" button at the same time :/
Thanks for the response by the way, I really appreciate it.
Lunik
Post by Lunik » Sat Dec 17, 2011 1:35 am
Ok nevermind, I feel like an idiot haha. Consider this solved - I didnt realize that recording made the other tracks playback again. I think I was using 1.2 before D:
Post by kozikowski » Sat Dec 17, 2011 2:47 am
Yes, but you need to have Audacity Preferences > Recording > Overdub... selected to get that.
polkat
Post by polkat » Sat Dec 17, 2011 5:50 am
Also, as already mentioned, the tracks may record slightly out of sync. If they are out of sync on playback, that is what's called latency. There is a description of a good test/setup for latency in the Help files.
Post by steve » Sat Dec 17, 2011 12:18 pm
polkat wrote:If they are out of sync on playback, that is what's called latency. There is a description of a good test/setup for latency in the Help files.
See here: http://manual.audacityteam.org/man/Latency_Test
