Recording in stereo (SOLVED)
natedog
Post by natedog » Wed Dec 14, 2011 3:26 pm
Hello, i've trying to record in stereo with my piano. I have a 1/8 " to 1/8" jack connecting my blue input jack on my computer to a 1/8" to 1/4" stereo adapter. the 1/4" adapter is plugged into piano's headphone jack. when i'm playing, i listen through my computers headphone jack and it sounds fine. but when i play it back it sounds weird. listen to the recording i attached. thanks for your help.
weird sounds.mp3
this is the weird sounding recording from my piano
(228.16 KiB) Downloaded 63 times
Re: Recording in stereo
Post by kozikowski » Wed Dec 14, 2011 3:43 pm
Welcome to Windows Corporate Conferencing Services. Windows thinks your playing is "air conditioning noise" and is trying its best to cancel it out. You can dig down and find the settings in the Windows Control Panels and turn it off.
If you have a "keyboard" rather than a real piano, you can hold one low organ note down for an extended period and watch it gargle and vanish on the recorded timeline.
-- Windows Conferencing Services
http://forum.audacityteam.org/viewtopic ... 79&start=0
http://manual.audacityteam.org/man/FAQ: ... hancements
Chances are the headphones are coming directly from the sound card, but the playback is coming from the computer.
Post by steve » Wed Dec 14, 2011 5:30 pm
kozikowski wrote:Windows Conferencing Services
This is Koz's (unique) term for audio "Enhancements"
natedog
Post by natedog » Sat Dec 17, 2011 4:31 pm
sooo... what do i need to do. i have xp if that helps. where would i go to fix that?
Trebor
Post by Trebor » Sat Dec 17, 2011 6:37 pm
natedog wrote:sooo... what do i need to do. i have xp if that helps. where would i go to fix that?
Windows sound settings are often optimised for VoIP (internet calls) using programs such as Skype, but these settings can interfere with high quality microphone recordings of music. Turn off all VoIP enhancements and any other sound effects unless they are essential:
Right-click over "Microphone" and choose "Properties" then look for an "Enhancements" tab where you can "Disable all sound effects" (if necessary, also look in the "Levels" or "Custom" tabs and on the main "Playback" tab for unwanted sound effects)
http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
The controls to fix this can be in the soundcard section (e.g. click on "SoundMax") ...
Then disable any "Microphone Enhancements" / "Voice Recording" or similar sounding options, and tick "No Filtering" if it exists.
natedog
Post by natedog » Sat Dec 17, 2011 10:06 pm
works now without any weird sound. i have a Realtek audio sound card. this is what i did.
go to microphone tab:
turn off "noise suppresion" and "aucostic echo cancelation"
go to mixer tab
mute "line volume", "front mic", and "microphone" and only leave stero unmuted.
thanks everyone. :)
Re: Recording in stereo (SOLVED)
Post by steve » Sun Dec 18, 2011 2:43 pm
Marked as SOLVED and moved to the Windows board.
