[SOLVED] Audacity require to be "installed" - cannot start
Sprinterdriver
Installed Visual C++ 2008 SP1 Redistributable Package (x86)
Post by Sprinterdriver » Fri Dec 16, 2011 4:25 pm
steve wrote:See here for a possible solution:
http://forum.audacityteam.org/viewtopic ... 745#p45745
Thanks a lot. It turned out that Visual C++ 2008 SP1 Redistributable Package (x86) is critical for Audacity to work.
There should be added a feature to Audacity that read a errormessage saying that this package must be installed in order for Audacity work.
How could I possible know this when error message tell me to reinstall Audacity?
Again, thanks :D
Re: [SOLVED] Audacity require to be "installed" - cannot sta
Post by steve » Fri Dec 16, 2011 4:59 pm
Thanks for the feedback and glad that it's now working :)
Sprinterdriver wrote:There should be added a feature to Audacity that read a errormessage saying that this package must be installed in order for Audacity work.
As far as I'm aware this is not an Audacity problem - the error and error message come from Windows, so unless Microsoft decide to make Windows open source (about as likely as Ali Khamenei becoming the next US President) there's nothing that Audacity can do about it. Audacity already ships with the correct dll's but for some reason Windows sometimes substitutes the wrong ones. This is not a common problem, but thanks to your feedback I'm now in a better position to help anyone else that has this problem.
Post by Gale Andrews » Sat Dec 17, 2011 4:42 pm
David Rose has confirmed that he has two XP Pro SP3 machines, one of which would not launch 1.3.14. Installing the appropriate Visual C++ 2008 SP1 Redistributable Package lets the machine that had the Audacity launch problem launch 1.3.14 OK.
