Plug ins to make the sound sounds like it was cut
shiraru
Post by shiraru » Sun Dec 11, 2011 4:50 am
Hello.
I'm just wondering, is there any plug ins to make the voice sounded like it was cut smoothly? Here are some examples:
At 0:31 - 0:32
http://www.youtube.com/watch?v=yDqZ1b4jltw&feature=g-u
and this song at 0:18 - 0:32
http://www.youtube.com/watch?v=J9v1bzSMsgM
I have tried to cut it manually, but it doesn't come out as good.
If there isn't one, does anyone have any advice to make it sound as good?
Thank you in advance. :)
Re: Plug ins to make the sound sounds like it was cut
Post by steve » Sun Dec 11, 2011 5:16 am
There's a similar effect discussed in this topic: http://forum.audacityteam.org/viewtopic ... 28&t=11169
shiraru
Post by shiraru » Sun Dec 11, 2011 6:01 am
I'm sorry for making a "re-post". Next time, I will sure to check the threads until the end (I just browsed until 5th page and just stop) so I won't make the same mistake again.
Thank you for the thread link!
Trebor
Post by Trebor » Sun Dec 11, 2011 6:34 pm
shiraru wrote:... make the voice sounded like it was cut ...
At 0:31 - 0:32
* http://www.youtube.com/watch?v=yDqZ1b4jltw&feature=g-u
Sounds similar to a "chopper" effect (at about 7Hz) has been applied to the vocal (only) ...
[* Ouch, none can sing in tune, that's one for "Guantanamo Greatest Hits"]
