create silence
guitarious
create silence
Post by guitarious » Sun Dec 11, 2011 1:58 am
Hi
Pretty simple problem,but its left me scratching my head. I have a small bass sound that I want to repeat to create a techno beat.I want to add the effect repeat and just have it play over and over. I need to create silence or extend the track to one second,but it always stops ay .75. How do I solve this?
Thanks
aud silence.jpg (119.68 KiB) Viewed 487 times
Re: create silence
Post by steve » Sun Dec 11, 2011 3:33 am
When you use the "Repeat" effect (item 21 in the Effect menu), the Selection is repeated, not just the audio clip. If you wish to repeat the first 1 second of that track, select the first 1 second and use the Repeat effect.
1 second selection.png (8.7 KiB) Viewed 483 times
