moving to wxWidgets 3.0
Building and customizing Audacity from the source code.
Edgar
Forum Crew
Post by Edgar » Tue Dec 06, 2011 8:07 pm
Currently Audacity will not build with any wxWidgets release beyond the 2.8 series; wx29 has many bug fixes which might benefit Audacity but the Audacity code needs some massaging to make it wx29+ compliant. The included patch is stale and will need to be applied manually, it was current as of when I created it but changes will have been made since then! I can only test this on Windows 7 so other OSes will have minor differences which are not explored here.
On Windows one must change all the solutions (there are 25 of them currently--Audacity, help, libflac, tolame etc.) and each solution's configuration (currently 4, but the non-Unicode ones may not exist for long--Release, Debug, Unicode Release & Unicode Debug) so that they use the wx29 libraries. To do this open each solution's property page's Linker's Input panel's Additional Dependencies dialog:
wxbase28ud.lib will change to wxbase29ud.lib etc. (or maybe even wxbase30ud.lib depending on the version of wxWidgets you are targeting). Many of the solutions may not link with the wxWidgets libraries--if one of any solution's configuration does not then none of its configurations do; only a few will need to be changed.
Don't forget to change your WXWIN environmental variable to point to your wx29 folder; this will need to be done before opening VC++ and may even require a reboot to take full effect.
Code: Select all
Index: lib-src/ffmpeg/libavutil/common.h
--- lib-src/ffmpeg/libavutil/common.h   (revision 11306)
+++ lib-src/ffmpeg/libavutil/common.h   (working copy)
@@ -36,6 +36,8 @@
#include <string.h>
#include "attributes.h"
+#include "../win32/stdint.h"
//rounded division & shift
#define RSHIFT(a,b) ((a) > 0 ? ((a) + ((1<<(b))>>1))>>(b) : ((a) + ((1<<(b))>>1)-1)>>(b))
/* assume b>0 */
Index: lib-src/portaudio-v19/src/hostapi/dsound/pa_win_ds.c
--- lib-src/portaudio-v19/src/hostapi/dsound/pa_win_ds.c   (revision 11306)
+++ lib-src/portaudio-v19/src/hostapi/dsound/pa_win_ds.c   (working copy)
@@ -102,7 +102,8 @@
#include "pa_win_ds.h"
#include "pa_win_ds_dynlink.h"
#include "pa_win_waveformat.h"
-#include "pa_win_wdmks_utils.h"
+//#include "pa_win_wdmks_utils.h"
+#include "../../os/win/pa_win_wdmks_utils.h"
#if (defined(WIN32) && (defined(_MSC_VER) && (_MSC_VER >= 1200))) /* MSC version 6 and above */
Index: lib-src/twolame/libtwolame/common.h
--- lib-src/twolame/libtwolame/common.h   (revision 11306)
+++ lib-src/twolame/libtwolame/common.h   (working copy)
@@ -27,12 +27,12 @@
#define _COMMON_H
#ifdef _WIN32
-# include "../win32/configwin.h"
+#include "configwin.h"
  * When building as a Win32 DLL, some functions are not allowed to be inlined,
  * otherwise the Microsoft Visual Studio 2005 linker will complain
-# define NO_DLL_INLINE
+#define NO_DLL_INLINE
#else
# include "config.h"
Index: src/AudacityApp.cpp
--- src/AudacityApp.cpp   (revision 11306)
+++ src/AudacityApp.cpp   (working copy)
@@ -603,7 +603,7 @@
       if (!cmd.IsEmpty()) {
          wxCommandEvent e(EVT_OPEN_AUDIO_FILE);
          e.SetString(data);
-         project->AddPendingEvent(e);
+         project->GetEventHandler()->AddPendingEvent(e);
       return true;
@@ -651,7 +651,7 @@
    e.SetString(fileName);
-   AddPendingEvent(e);
+   GetEventHandler()->AddPendingEvent(e);
// in response of a print-document apple event
@@ -663,7 +663,7 @@
// in response of a open-application apple event
Index: src/AudioIO.cpp
--- src/AudioIO.cpp   (revision 11306)
+++ src/AudioIO.cpp   (working copy)
@@ -550,7 +550,7 @@
       wxString errStr = _("Could not find any audio devices.n");
       errStr += _("You will not be able to play or record audio.nn");
       wxString paErrStr = LAT1CTOWX(Pa_GetErrorText(err));
-      if (paErrStr)
+      if (paErrStr != wxEmptyString)
          errStr += _("Error: ")+paErrStr;
       // XXX: we are in libaudacity, popping up dialogs not allowed!  A
       // long-term solution will probably involve exceptions
Index: src/commands/ScriptCommandRelay.cpp
--- src/commands/ScriptCommandRelay.cpp   (revision 11306)
+++ src/commands/ScriptCommandRelay.cpp   (working copy)
@@ -57,7 +57,7 @@
    wxASSERT(cmd != NULL);
    AppCommandEvent ev;
    ev.SetCommand(cmd);
-   project->AddPendingEvent(ev);
+   project->GetEventHandler()->AddPendingEvent(ev);
/// This is the function which actually obeys one command.  Rather than applying
Index: src/effects/Compressor.cpp
--- src/effects/Compressor.cpp   (revision 11306)
+++ src/effects/Compressor.cpp   (working copy)
@@ -38,6 +38,7 @@
#include <wx/textdlg.h>
#include <wx/brush.h>
#include <wx/image.h>
+#include <wx/dcclient.h>
#include <wx/dcmemory.h>
#include "Compressor.h"
Index: src/effects/VST/VSTEffect.cpp
--- src/effects/VST/VSTEffect.cpp   (revision 11306)
+++ src/effects/VST/VSTEffect.cpp   (working copy)
@@ -32,6 +32,7 @@
#include <wx/stattext.h>
#include <wx/stopwatch.h>
#include <wx/utils.h>
+#include <wx/textctrl.h>
#if defined(__WXMAC__)
#include <dlfcn.h>
@@ -41,6 +42,10 @@
#endif
#if defined(__WXMSW__)
+   #include <wx/msw/wrapwin.h>
+   #include <WinBase.h>
+   #include <WinDef.h>
+   #include <WinNT.h>
    #include <wx/msw/seh.h>
    #include <windows.h>
    #include <shlwapi.h>
Index: src/import/ImportRaw.cpp
--- src/import/ImportRaw.cpp   (revision 11306)
+++ src/import/ImportRaw.cpp   (working copy)
@@ -323,7 +323,7 @@
       if (sf_format_check(&info)) {
          mEncodingSubtype[mNumEncodings] = subtype;
-         encodings.Add(LAT1CTOWX(sf_encoding_index_name(i)));
+         encodings.Add(wxString (sf_encoding_index_name(i).wc_str(), wxConvISO8859_1));
          if ((mEncoding & SF_FORMAT_SUBMASK) == subtype)
             selection = mNumEncodings;
Index: src/Internat.h
--- src/Internat.h   (revision 11306)
+++ src/Internat.h   (working copy)
@@ -12,6 +12,7 @@
#ifndef __AUDACITY_INTERNAT__
#define __AUDACITY_INTERNAT__
+#include <wx/thread.h>
#include <wx/arrstr.h>
#include <wx/string.h>
#include <wx/longlong.h>
Index: src/ondemand/ODManager.cpp
--- src/ondemand/ODManager.cpp   (revision 11306)
+++ src/ondemand/ODManager.cpp   (working copy)
@@ -311,7 +311,7 @@
          AudacityProject::AllProjectsDeleteLock();
          AudacityProject* proj = GetActiveProject();
          if(proj)
-            proj->AddPendingEvent( event );
+            proj->GetEventHandler()->AddPendingEvent( event );
          AudacityProject::AllProjectsDeleteUnlock();
       mTerminateMutex.Lock();
Index: src/ondemand/ODTask.cpp
--- src/ondemand/ODTask.cpp   (revision 11306)
+++ src/ondemand/ODTask.cpp   (working copy)
@@ -158,7 +158,7 @@
          if(IsTaskAssociatedWithProject(gAudacityProjects[i]))
             //this assumes tasks are only associated with one project.
-            gAudacityProjects[i]->AddPendingEvent( event );
+            gAudacityProjects[i]->GetEventHandler()->AddPendingEvent( event );
             //mark the changes so that the project can be resaved.
             gAudacityProjects[i]->GetUndoManager()->SetODChangesFlag();
             break;
Index: src/PitchName.cpp
--- src/PitchName.cpp   (revision 11306)
+++ src/PitchName.cpp   (working copy)
@@ -16,7 +16,7 @@
+#include <wx/string.h>
#include <math.h>
#include <stdio.h>
Index: src/prefs/KeyConfigPrefs.cpp
--- src/prefs/KeyConfigPrefs.cpp   (revision 11306)
+++ src/prefs/KeyConfigPrefs.cpp   (working copy)
@@ -122,6 +122,7 @@
@@ -350,7 +352,7 @@
       nevent.SetDirection(!e.ShiftDown());
       nevent.SetEventObject(t);
       nevent.SetCurrentFocus(t);
-      t->GetParent()->ProcessEvent(nevent);
+      t->GetParent()->GetEventHandler()->ProcessEvent(nevent);
       return;
Index: src/Project.cpp
--- src/Project.cpp   (revision 11306)
+++ src/Project.cpp   (working copy)
@@ -1657,7 +1703,7 @@
       wxCommandEvent e(EVT_CAPTURE_KEY);
       e.SetEventObject(&event);
-      if (w->ProcessEvent(e)) {
+      if (w->GetEventHandler()->ProcessEvent(e)) {
          return false;
Index: src/Tags.cpp
--- src/Tags.cpp   (revision 11306)
+++ src/Tags.cpp   (working copy)
@@ -482,7 +482,8 @@
       while (*attrs) {
          wxString attr = *attrs++;
-         if (!*attr)
+         if (attr == wxEmptyString)
             break;
          wxString value = *attrs++;
Index: src/toolbars/ControlToolBar.cpp
--- src/toolbars/ControlToolBar.cpp   (revision 11306)
+++ src/toolbars/ControlToolBar.cpp   (working copy)
@@ -586,10 +586,10 @@
       else {
          // msmeyer: Show error message if stream could not be opened
-         wxMessageBox(_(
-            "Error while opening sound device. "
-            wxT("Please check the output device settings and the project sample rate.")),
-            _("Error"), wxOK | wxICON_EXCLAMATION, this);
+         wxString messageA(_("Error while opening sound device. "));
+         wxString messageB(wxT("Please check the output device settings and the project sample rate."));
+         messageA.Append(messageB);
+         wxMessageBox(messageA, _("Error"), wxOK | wxICON_EXCLAMATION, this);
@@ -928,9 +928,10 @@
-         wxMessageBox(_("Error while opening sound device. "
-            wxT("Please check the input device settings and the project sample rate.")),
+         wxString messageB(wxT("Please check the input device settings and the project sample rate."));
          SetPlay(false);
          SetStop(false);
Index: src/toolbars/DeviceToolBar.cpp
--- src/toolbars/DeviceToolBar.cpp   (revision 11306)
+++ src/toolbars/DeviceToolBar.cpp   (working copy)
@@ -72,8 +72,8 @@
    ToolBar::Create(parent);
    // Simulate a size event to set initial meter placement/size
-   wxSizeEvent dummy;
-   OnSize(dummy);
+   //wxSizeEvent dummy;//efm5 debug figure this out
+   //OnSize(dummy);//wx's V says Layout() or just nothing
void DeviceToolBar::RecreateTipWindows()
Index: src/toolbars/ToolDock.h
--- src/toolbars/ToolDock.h   (revision 11306)
+++ src/toolbars/ToolDock.h   (working copy)
@@ -40,8 +40,8 @@
enum
    NoDockID = 0,
-   TopDockID,
-   BotDockID,
+   TopDockID = 2,
+   BotDockID = 3,
    DockCount = 2
Index: src/toolbars/ToolManager.cpp
--- src/toolbars/ToolManager.cpp   (revision 11306)
+++ src/toolbars/ToolManager.cpp   (working copy)
@@ -740,12 +740,24 @@
       gPrefs->SetPath( bar->GetSection() );
       // Search both docks for toolbar order
-      int to = mTopDock->GetOrder( bar );
-      int bo = mBotDock->GetOrder( bar );
+      int top = mTopDock->GetOrder( bar );
+      int bottom = mBotDock->GetOrder( bar );
       // Save
-      gPrefs->Write( wxT("Dock"), to ? TopDockID : bo ? BotDockID : NoDockID );
-      gPrefs->Write( wxT("Order"), to + bo );
+      wxString dock;
+      if (top) {
+         dock.Printf(wxT("%d"), TopDockID);
+         gPrefs->Write( wxT("Dock"), dock );
+      else if (bottom) {
+         dock.Printf(wxT("%d"), BotDockID);
+      else {
+         dock.Printf(wxT("%d"), NoDockID);
+      gPrefs->Write( wxT("Order"), (top + bottom) );
       gPrefs->Write( wxT("Show"), IsVisible( ndx ) );
       wxPoint pos( -1, -1 );
Index: src/toolbars/ToolsToolBar.cpp
--- src/toolbars/ToolsToolBar.cpp   (revision 11306)
+++ src/toolbars/ToolsToolBar.cpp   (working copy)
@@ -59,18 +59,18 @@
// Strings to convert a tool number into a status message
// These MUST be in the same order as the ids above.
-const wxChar * MessageOfTool[numTools] = { wxTRANSLATE("Click and drag to select audio"),
-   wxTRANSLATE("Click and drag to edit the amplitude envelope"),
-   wxTRANSLATE("Click and drag to edit the samples"),
+const wxChar * MessageOfTool[numTools] = { _("Click and drag to select audio"),
+   _("Click and drag to edit the amplitude envelope"),
+   _("Click and drag to edit the samples"),
#if defined( __WXMAC__ )
-   wxTRANSLATE("Click to Zoom In, Shift-Click to Zoom Out"),
+   _("Click to Zoom In, Shift-Click to Zoom Out"),
#elif defined( __WXMSW__ )
-   wxTRANSLATE("Drag to Zoom Into Region, Right-Click to Zoom Out"),
+   _("Drag to Zoom Into Region, Right-Click to Zoom Out"),
#elif defined( __WXGTK__ )
-   wxTRANSLATE("Left=Zoom In, Right=Zoom Out, Middle=Normal"),
+   _("Left=Zoom In, Right=Zoom Out, Middle=Normal"),
#endif
-   wxTRANSLATE("Click and drag to move a track in time"),
-   wxT("") // multi-mode tool
+   _("Click and drag to move a track in time"),
+   wxString(wxEmptyString) // multi-mode tool
Index: src/TrackPanel.cpp
--- src/TrackPanel.cpp   (revision 11306)
+++ src/TrackPanel.cpp   (working copy)
@@ -4768,7 +4763,7 @@
       // The activate event is used to make the
       // parent window 'come alive' if it didn't have focus.
       wxActivateEvent e;
-      GetParent()->ProcessEvent(e);
+      GetParent()->GetEventHandler()->ProcessEvent(e);
       // wxTimers seem to be a little unreliable, so this
       // "primes" it to make sure it keeps going for a while...
@@ -5199,28 +5203,42 @@
    int trackKind = pTrack->GetKind();
    currentTool = selectTool; // the default.
-   if( event.ButtonIsDown(3) || event.RightUp()){
+   if( event.RightIsDown() || event.RightUp())
       currentTool = zoomTool;
-   } else if( trackKind == Track::Time ){
+   else if( trackKind == Track::Time )
       currentTool = envelopeTool;
-   } else if( trackKind == Track::Label ){
+   else if( trackKind == Track::Label )
-   } else if( trackKind != Track::Wave) {
+   else if( trackKind != Track::Wave)
    // So we are in a wave track.
    //FIX-ME: Not necessarily. Haven't checked Track::Note (#if defined(USE_MIDI)).
    // From here on the order in which we hit test determines
    // which tool takes priority in the rare cases where it
    // could be more than one.
-   } else if (event.CmdDown()){
+   else if (event.CmdDown())
       // msmeyer: If control is down, slide single clip
       // msmeyer: If control and shift are down, slide all clips
       currentTool = slideTool;
-   } else if( HitTestEnvelope( pTrack, r, event ) ){
+   else if( HitTestEnvelope( pTrack, r, event ) )
-   } else if( HitTestSlide( pTrack, r, event )){
+   else if( HitTestSlide( pTrack, r, event ))
-   } else if( HitTestSamples( pTrack, r, event )){
+   else if( HitTestSamples( pTrack, r, event )){
       currentTool = drawTool;
@@ -7712,28 +7737,27 @@
TrackInfo::TrackInfo(wxWindow * pParentIn)
+   mpFont = NULL;
    pParent = pParentIn;
    // Populate sliders array
    for (unsigned int i = 0; i < kInitialSliders; ++i) {
       MakeMoreSliders();
    mSliderOffset = 0;
-   int fontSize = 10;
-   mFont.Create(fontSize, wxSWISS, wxNORMAL, wxNORMAL);
    int allowableWidth = GetTrackInfoWidth() - 2; // 2 to allow for left/right borders
    int textWidth, textHeight;
+   int fontSize = 10;
+   mpFont = new wxFont(fontSize, wxFONTFAMILY_SWISS,
+                       wxFONTSTYLE_NORMAL,
+                       wxFONTWEIGHT_NORMAL);//no mem alloc testing
    do {
-      mFont.SetPointSize(fontSize);
+      mpFont->SetPointSize(fontSize);
       pParent->GetTextExtent(_("Stereo, 999999Hz"),
-                             &textWidth,
-                             &textHeight,
-                             NULL,
-                             NULL,
-                             &mFont);
+                             &textWidth, &textHeight,
+                             NULL, NULL, mpFont);
       fontSize--;
    } while (textWidth >= allowableWidth);
@@ -7745,6 +7769,7 @@
       delete mGains[i];
    for(i=0; i<mPans.Count(); i++)
       delete mPans[i];
+   if (mpFont) delete mpFont;
static const int kTrackInfoWidth = 100;
@@ -7826,7 +7851,7 @@
/// todo Probably should move to 'Utils.cpp'.
void TrackInfo::SetTrackInfoFont(wxDC * dc)
-   dc->SetFont(mFont);
+   dc->SetFont(*mpFont);
void TrackInfo::DrawBordersWithin(wxDC* dc, const wxRect r, bool bHasMuteSolo)
Index: src/TrackPanel.h
--- src/TrackPanel.h   (revision 11306)
+++ src/TrackPanel.h   (working copy)
@@ -143,7 +143,7 @@
    LWSlider * PanSlider(int trackIndex);
    wxWindow * pParent;
-   wxFont mFont;
+   wxFont * mpFont;
    friend class TrackPanel;
Index: src/UploadDialog.cpp
--- src/UploadDialog.cpp   (revision 11306)
+++ src/UploadDialog.cpp   (working copy)
@@ -123,12 +123,12 @@
     icons->Add(*mp3Icon);
     icons->Add(*upIcon);
-    wxFlexGridSizer *topSizer = new wxFlexGridSizer(2, 1);
+    wxFlexGridSizer *topSizer = new wxFlexGridSizer(2, 1, 0);
     wxStaticBoxSizer *connectionBox = new wxStaticBoxSizer(new wxStaticBox(this, -1, wxT("FTP Connection"), wxDefaultPosition, wxDefaultSize, 0, wxT("")), wxVERTICAL);
     wxStaticBoxSizer *fileBox = new wxStaticBoxSizer(new wxStaticBox(this, -1, wxT("File Manager"), wxDefaultPosition, wxDefaultSize, 0, wxT("")), wxVERTICAL);
     wxStaticBoxSizer *siteBox = new wxStaticBoxSizer(new wxStaticBox(this, -1, wxT("Site Manager"), wxDefaultPosition, wxDefaultSize, 0, wxT("")), wxVERTICAL);
-    wxFlexGridSizer *connectionSizer = new wxFlexGridSizer(2, 4);
+    wxFlexGridSizer *connectionSizer = new wxFlexGridSizer(2, 4, 0);
     wxBoxSizer *leftSizer = new wxBoxSizer(wxVERTICAL);
     wxBoxSizer *rightSizer = new wxBoxSizer(wxVERTICAL);
     wxBoxSizer *fileButtonSizer = new wxBoxSizer(wxHORIZONTAL);
Index: src/widgets/ASlider.cpp
--- src/widgets/ASlider.cpp   (revision 11306)
+++ src/widgets/ASlider.cpp   (working copy)
@@ -1191,7 +1191,7 @@
                nevent.SetDirection( !event.ShiftDown() );
                nevent.SetEventObject( mParent );
                nevent.SetCurrentFocus( mParent );
-               mParent->GetParent()->ProcessEvent( nevent );
+               mParent->GetParent()->GetEventHandler()->ProcessEvent( nevent );
             break;
@@ -1203,7 +1203,7 @@
                if (def && def->IsEnabled()) {
                   wxCommandEvent cevent(wxEVT_COMMAND_BUTTON_CLICKED,
                         def->GetId());
-                  mParent->ProcessEvent(cevent);
+                  mParent->GetEventHandler()->ProcessEvent(cevent);
@@ -1228,7 +1228,7 @@
    int intValue = (int)( ( mCurrentValue - mMinValue ) * 1000.0f /
                          ( mMaxValue - mMinValue ) );
    e.SetInt( intValue );
-   mParent->ProcessEvent( e );
+   mParent->GetEventHandler()->ProcessEvent( e );
int LWSlider::ValueToPosition(float val)
Index: src/widgets/Grabber.cpp
--- src/widgets/Grabber.cpp   (revision 11306)
+++ src/widgets/Grabber.cpp   (working copy)
@@ -83,7 +83,7 @@
    e.SetEventObject(parent);
    // Queue the event
-   parent->AddPendingEvent(e);
+   parent->GetEventHandler()->AddPendingEvent(e);
Index: src/widgets/Grid.cpp
--- src/widgets/Grid.cpp   (revision 11306)
+++ src/widgets/Grid.cpp   (working copy)
@@ -28,7 +28,7 @@
TimeEditor::TimeEditor()
-   TimeEditor(wxT("seconds"), 44100);
+   TimeEditor(wxT("seconds"), 44100.0);
TimeEditor::TimeEditor(const wxString &format, double rate)
@@ -303,8 +303,7 @@
    Choice()->SetFocus();
-bool ChoiceEditor::EndEdit(int row, int col,
-                           wxGrid* grid)
+bool ChoiceEditor::EndEdit(int row, int col, wxGrid * grid)
    wxString val = mChoices[Choice()->GetSelection()];
@@ -492,7 +491,7 @@
                                      def->GetId());
-               GetParent()->ProcessEvent(cevent);
+               GetParent()->GetEventHandler()->ProcessEvent(cevent);
          else {
Index: src/widgets/Grid.h
--- src/widgets/Grid.h   (revision 11306)
+++ src/widgets/Grid.h   (working copy)
@@ -53,6 +53,8 @@
    void BeginEdit(int row, int col, wxGrid *grid);
    bool EndEdit(int row, int col, wxGrid *grid);
+   bool EndEdit(int row, int col, const wxGrid *grid, const wxString& oldval, wxString *newval);
+   void ApplyEdit(int row, int col, wxGrid* grid);
    void Reset();
@@ -125,6 +127,9 @@
+                const wxString& oldval, wxString *newval);
    void Reset();
Index: src/widgets/ImageRoll.cpp
--- src/widgets/ImageRoll.cpp   (revision 11306)
+++ src/widgets/ImageRoll.cpp   (working copy)
@@ -100,6 +100,8 @@
#include <wx/bitmap.h>
+#include <wx/defs.h>
WX_DEFINE_OBJARRAY(BitmapArray);
WX_DEFINE_OBJARRAY(ImageArray);
@@ -299,19 +301,19 @@
void ImageRoll::DrawBitmap(wxDC &dc, wxBitmap &bitmap,
-                           int x, int y, int logicalFunc)
+                           int x, int y, wxRasterOperationMode logicalFunction)
-   if (logicalFunc == wxCOPY)
+   if (logicalFunction == wxCOPY)
       dc.DrawBitmap(bitmap, x, y);
    else {
       wxMemoryDC memDC;
       memDC.SelectObject(bitmap);
       dc.Blit(x, y, bitmap.GetWidth(), bitmap.GetHeight(),
-              &memDC, 0, 0, logicalFunc);
+         &memDC, 0, 0, logicalFunction);
-void ImageRoll::Draw(wxDC &dc, wxRect rect, int logicalFunc)
+void ImageRoll::Draw(wxDC &dc, wxRect rect, wxRasterOperationMode logicalFunction)
    int width = rect.width;
    int height = rect.height;
@@ -434,9 +436,9 @@
                 mImageRoll.GetMaxSize());
-void ImageRollPanel::SetLogicalFunction(int func)
+void ImageRollPanel::SetLogicalFunction(wxRasterOperationMode logicalFunction)
-   mLogicalFunction = func;
+   mLogicalFunction = logicalFunction;
void ImageRollPanel::OnPaint(wxPaintEvent &evt)
Index: src/widgets/ImageRoll.h
--- src/widgets/ImageRoll.h   (revision 11306)
+++ src/widgets/ImageRoll.h   (working copy)
@@ -15,6 +15,7 @@
#include <wx/dynarray.h>
#include <wx/panel.h>
+#include <wx/dc.h>
WX_DECLARE_OBJARRAY(wxBitmap, BitmapArray);
WX_DECLARE_OBJARRAY(wxImage, ImageArray);
@@ -40,7 +41,7 @@
    wxSize GetMaxSize() const { return mMaxSize; }
    void Draw(wxDC &dc, wxRect rect,
-             int logicalFunc = wxCOPY);
+             wxRasterOperationMode logicalFunction = wxCOPY);
    static ImageArray SplitH(const wxImage &src, wxColour magicColor);
    static ImageArray SplitV(const wxImage &src, wxColour magicColor);
@@ -48,7 +49,7 @@
  protected:
    void DrawBitmap(wxDC &dc, wxBitmap &bitmap,
-                   int x, int y, int logicalFunc = wxCOPY);
+                   int x, int y, wxRasterOperationMode logicalFunction = wxCOPY);
    void Init(RollType type, const wxImage &src, wxColour magicColor);
@@ -72,7 +73,7 @@
                   const wxSize& size = wxDefaultSize,
                   long style = wxTAB_TRAVERSAL);
-   void SetLogicalFunction(int func);
+   void SetLogicalFunction(wxRasterOperationMode logicalFunction);
    void OnPaint(wxPaintEvent &evt);
    void OnSize(wxSizeEvent &evt);
@@ -80,7 +81,7 @@
  protected:
    ImageRoll mImageRoll;
-   int mLogicalFunction;
+   wxRasterOperationMode mLogicalFunction;
    DECLARE_EVENT_TABLE();
Index: src/widgets/TimeTextCtrl.cpp
--- src/widgets/TimeTextCtrl.cpp   (revision 11306)
+++ src/widgets/TimeTextCtrl.cpp   (working copy)
@@ -176,6 +176,7 @@
#include <wx/tooltip.h>
#include <wx/toplevel.h>
#ifdef _DEBUG
     #ifdef _MSC_VER
@@ -1152,7 +1153,7 @@
       nevent.SetDirection(!event.ShiftDown());
       nevent.SetEventObject(parent);
       nevent.SetCurrentFocus(parent);
-      GetParent()->ProcessEvent(nevent);
+      GetParent()->GetEventHandler()->ProcessEvent(nevent);
    else if (keyCode == WXK_RETURN || keyCode == WXK_NUMPAD_ENTER) {
@@ -1161,7 +1162,7 @@
                                def->GetId());
Index: src/xml/XMLWriter.cpp
--- src/xml/XMLWriter.cpp   (revision 11306)
+++ src/xml/XMLWriter.cpp   (working copy)
@@ -246,7 +246,7 @@
       mHasKids[0] = true;
-   Write(value.c_str());
+   Write(value);
void XMLWriter::WriteSubTree(const wxChar *value)
Some of the above changes may already have been made, others might be needed! There are a few included changes which only affect readability of the code but I made them to help diagnosing the build errors and left them in as they improve things for everyone (I think <grin> !).
I would suggest following this procedure:
1) download & compile current wxWidgets stable post-2.8 version
2) set WXWIN environmental variable
3) reboot
4) checkout a clean Audacity SVN HEAD
5) open the audacity.sln in VC++ and make all the needed Linker library changes
6) search all Audacity source code for every instance of "AddPendingEvent" it will find a bunch of lines like:
AddPendingEvent(e);
change them to:
(remember the (e) might really be (event) then use "GetEventHandler()->AddPendingEvent(event);" etc.
7) use Batch Build to compile everything (this will get the entire Audacity solution including help and locale plus all the external libraries). You will get a lot of errors!
8) I found it easiest to start with the external libraries--fewer changes--so open the Solution Explorer window and start at the bottom "twolame"--right-click to get a context menu, choose Project Only > Build only twolame, fix errors until it builds then move up to "soundtouch" and continue.
When you hit an error search through the above patch to find the solution (or a similar solution) and apply the fix manually. If you get stuck, post here and I will try to help.
LaurentFr
Re: moving to wxWidgets 2.9+
Post by LaurentFr » Mon Jul 23, 2012 1:30 pm
Thanks you for example.
I have followed your script but there is something that I don't understand :
when you change
and you append applyedit
what are the new functions ?
Thanks you for yours answwers
Edgar
Forum Crew
Post by Edgar » Mon Jul 23, 2012 5:08 pm
LaurentFr wrote: I have followed your script but there is something that I don't understand :
when you change
You obviously studied this very carefully! It has been a long time since my post and to be honest, I am not entirely sure of the answer. I think that this is just holdover code from another bit of work someone else (not I--I would not use variable names like oldval) was doing at the time and has nothing to do with moving to wx2.9. Just ignore it--it's addition will cause no harm but is not needed.
LaurentFr
Post by LaurentFr » Mon Jul 23, 2012 6:09 pm
A bad solution for my problem of source code of functions :
void TimeEditor::ApplyEdit(int row, int col, wxGrid* grid){};
//bool TimeEditor::EndEdit(int row, int col, wxGrid *grid)
bool TimeEditor::EndEdit(int row, int col,const wxGrid *grid, const wxString& oldval, wxString *newval)
After Link is ok! If I run the program I have got some warning abut Font and Police, but Audacity is running, playing sound....!
Thanks
PS Audacity log file is
21:11:21: Audacity 2.0.2-alpha-Jul 23 2012
21:11:22: Error: locale 'fr' cannot be set.
DirManager: Created new instance.
21:11:38: Trying to load FFmpeg libraries...
21:11:38: Trying to load FFmpeg libraries from system paths. File name is 'avformat-52.dll'.
21:11:38: Looking up PATH environment variable...
21:11:38: PATH = 'C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem;C:Program FilesATI TechnologiesATI Control Panel;C:Program FilesFichiers communsGTK2.0bin;djgppbin;C:Program Filesdoxygenbin;C:Program FilesSupport Tools;C:Program FilesMiKTeX 2.9miktexbin;C:Program Filesscilab-5.4.0-alpha-1bin;C:Program FilesTraiMisc;
21:11:38: Checking that '' is in PATH...
21:11:38: FFmpeg directory is in PATH.
21:11:38: Checking for monolithic avformat from 'avformat-52.dll'.
21:11:38: Error: Failed to load shared library 'avformat-52.dll' (error 126: le module spécifié est introuvable.)
21:11:38: Loading avutil from 'avutil-50.dll'.
21:11:38: Error: Failed to load shared library 'avutil-50.dll' (error 126: le module spécifié est introuvable.)
21:11:38: Loading avcodec from 'avcodec-52.dll'.
21:11:38: Error: Failed to load shared library 'avcodec-52.dll' (error 126: le module spécifié est introuvable.)
21:11:38: Loading avformat from 'avformat-52.dll'.
21:11:38: Error: Failed to load FFmpeg libraries.
21:11:38: Error: Failed to find compatible FFmpeg libraries.
LastOpenType is All files
OverrideExtendedImportByOpenFileDialogChoice is 0
21:12:12: File name is c:documents and settingslaurentbureauallonge3.wav
21:12:12: Mime type is *
Appending libsndfile
Appending libav
Appending liboggvorbis
Appending libflac
Appending lof
21:12:12: Opening with libsndfile
21:12:12: Open(c:documents and settingslaurentbureauallonge3.wav) succeeded
AudioIO::GetBestRate() for playback
GetBestRate() suggested rate 48000 Hz
GetBestRate() Returning 48000 Hz
Edgar
Forum Crew
Post by Edgar » Mon Jul 23, 2012 7:09 pm
LaurentFr wrote: After Link is ok! If I run the program I have got some warning abut Font and Police, but Audacity is running, playing sound....!
A "Very well done!" to you.
It would be nice if you were to do a patch against SVN HEAD with your changes and post it here like I did so that in the future others may have the benefit of your experience.
LaurentFr
Post by LaurentFr » Tue Jul 24, 2012 11:20 am
I didn't use exactly your modification for event handling. I use ProcessWindowEvent ( http://docs.wxwidgets.org/2.9.4/classwx ... 7e4eab2b57)
As soon as there is no warning I will try to create a new branch in SVN Header. If you want source code now I can give you a link to a zip file of my MSVC project with source code.
When I launch audacity and try to open a file the mask file int the dialog box is wrong. I have source file :
FileDialogPrivate.cpp
line 722
// of.lpstrFilter = (LPTSTR)((const char*)filterBuffer.c_str());
of.lpstrFilter = (LPTSTR)((const char*)filterBuffer.fn_str());
When I want to plot a spectrum there is an access violation at line :
in file FreqWindow.cpp line 747
value = CubicInterpolate(mProcessed[ibin],
mProcessed[ibin + 1],
mProcessed[ibin + 2],
mProcessed[ibin + 3], binmid - ibin);
value of ibin is -842150455 because value of mProcessedSize is -842150451. Variable Initialization ofmProcessSize must be done at line 1113 or 1133 1173 or 1192 in freqWindow.cpp in method FreqWindow::Recalc() but in debug mode program does not execute this line.
To solve this problem I have change source coode of FreqWindow.cpp at line 997 :
//Progress dialog over FFT operation
ProgressDialog *mProgress = new ProgressDialog(_("Plot Spectrum"),_("Drawing Spectrum"));
int start = 0;
int windows = 0;
mProcessedSize = half; // new line20120724
while (start + mWindowSize <= mDataLen) {
Now FFT is OK but I don't think that's a good answer. May be problem is in event handling(?)
Edgar
Forum Crew
Post by Edgar » Tue Jul 24, 2012 3:16 pm
LaurentFr wrote:I didn't use exactly your modification for event handling. I use ProcessWindowEvent ( http://docs.wxwidgets.org/2.9.4/classwx ... 7e4eab2b57)
My choice on event handling was a while back and based on what the wx folks recommended at the time; your's is probably more up-to-date.
I would love to DL your zipped version!
Edgar
Forum Crew
Post by Edgar » Thu Nov 14, 2013 3:42 am
Code: Select all
bool wxWindow::ProcessWindowEvent	(	wxEvent & 	event	)
Convenient wrapper for ProcessEvent().
This is the same as writing
 GetEventHandler()->ProcessEvent(event);
but more convenient. Notice that ProcessEvent() itself can't be called for wxWindow objects as it ignores the event handlers associated with the window; use this function instead.
I see that now and will adopt that version.
Edgar
Forum Crew
Re: moving to wxWidgets 3.0
Post by Edgar » Thu Nov 14, 2013 6:25 am
Here is a patch for SVN HEAD 12 November 2013 (revision 12937) which compiles (Release & Debug) with no errors and the only warnings are for libraries in lib-src which Audacity's Team does not control. You may not use setting.h as currently supplied with Audacity but must modify the one which comes with wxWidgets 3.0 (the only thing I did was to turn on accessibility:
Code: Select all
// Use wxAccessible for enhanced and customisable accessibility.
// Depends on wxUSE_OLE.
// Default is 0.
// Recommended setting (at present): 0
#define wxUSE_ACCESSIBILITY 1
2wx30.zip
(14.64 KiB) Downloaded 158 times
Edgar
Forum Crew
Post by Edgar » Thu Nov 14, 2013 9:58 pm
The previous patch neglected to update all of the wxFont stuff so, while it will run, it uses the default font everywhere. I hope to post a new patch sometime today with these fixes and a new set of step-by-step directions.
