Gverb
suttlemyre
Gverb
Post by suttlemyre » Wed Nov 30, 2011 8:55 pm
Acoustic guitar thru a mike. !.3 beta. Record a guitar trak,then would like to add a little reverb. What Gverb settings would you start out with? I cannot seem to get this to work well.
Re: Gverb
Post by steve » Wed Nov 30, 2011 9:12 pm
There is a guide to using GVerb here: http://wiki.audacityteam.org/wiki/GVerb
I would recommend using the "Duplicate and mix together" method.
polkat
Re: Gverb
Post by polkat » Wed Nov 30, 2011 10:05 pm
One thing I've noticed in Gverb is that if you don't have much Dry Signal Level, it sounds pretty bad. Try setting the dry level about 4/5ths up, the wet signal about half way or less, and all the timing silders within the first 1/3rd range. This works pretty good with my acoustic Yamaha. Trim to taste.
Re: Gverb
Post by steve » Wed Nov 30, 2011 10:28 pm
polkat wrote:One thing I've noticed in Gverb is that if you don't have much Dry Signal Level, it sounds pretty bad
The "Duplicate and mix together" method described on the wiki makes adjusting the mix of wet (processed) and dry (original) signal much easier as you can adjust it while it is playing.
