According to the
Instruction/Operation Manual for the ECM-MS957
the microphone has a stereo mini-jack plug and has a switch for selecting between 90 and 120 degree pick-up patterns.
I assume from the presence of this switch that the sum-and-difference matrix for decoding the mid-side stereo is built into the microphone and the output uses "conventional" stereo mini-jack wiring (right / left to tip / ring and common/earth to sleeve).
Although computer sound cards usually have stereo mini-jack connectors for the microphone input, they are not wired as "conventional" stereo mini-jack sockets.
Typical computer microphones are mono and require a power supply, so the computer mic socket supplies power on one contact and uses the other two contacts for signal (mono) and earth.
The ECM-MS957 is battery powered so it does not require the power connector, but instead it requires a stereo input. Basically this microphone is incompatible with a standard computer microphone input.
waxcylinder wrote:It ouputs into a 3.5mm stereo jack, so I'm guessing the wiring and the L/R orientation are all ok - but any insights you have would be useful and interesting.
If the recording sounds like stereo, then the mid-side stereo has been decoded.
Before it is decoded mid-side recording don't sound like stereo.
Decoding is just a matter of splitting the "side" recording (from a figure of 8 microphone) into left / right channels and inverting one side, then mixing in some of the "mid" (usually a cardioid mic) recording. This gives "Mid + Side" in one channel and "Mid - Side" in the other and (by magic) it sounds like stereo.
