Neostar Cassette Conversion System
Poppy1
Post by Poppy1 » Sat Nov 19, 2011 1:42 pm
I have a Mac OS X 10.7.2
I have just purchased a Neostar cassette conversion system which I can get to recognise or be recognised by the Mac
I was advised by the retailer to download audacity - which I have done, version 1.3.13-beta (Unicode)
A casette is playing in the Neostar device but I cannot hear anything
I have opened Audacity and at one stage it appeared to be recording external sound i.e. a nearby radio and me on the keyboard but is not recognising the Neostar device.
There is now an error message
"Error whilst opening sound device. Please check the input device setting and project sample rate "
This is the second Neostar device as I could not get the first one to work
Any help or advice would be much appreciated
Thank you
Poppy1
billw58
Re: Neostar Cassette Conversion System
Post by billw58 » Sun Nov 20, 2011 12:42 am
It probably connects to your Mac via the USB port, right?
If so, does this help?
http://wiki.audacityteam.org/wiki/User: ... ut_devices
-- Bill
Poppy1
Post by Poppy1 » Mon Nov 21, 2011 1:10 pm
Hi Bill
Thank you for your reply.
Did as you suggested but got lost at Audio Midi set up as the description on the web page looks nothing like my screen and was not sure what I was meant to be doing
So, still no further on
Thanks
Poppy1
billw58
Post by billw58 » Tue Nov 22, 2011 5:16 am
So after step 7 in the description you still could get no sound into Audacity? You don't need to use Audio MIDI Setup if you get sound at that point.
As noted, those screenshots are from 10.5.8. Someone who has 10.7 will have to chime in with what it looks like in that OS.
-- Bill
Poppy1
Post by Poppy1 » Tue Nov 22, 2011 12:22 pm
Thanks Bill
No, still no sound after Step 7
Thanks again
Poppy1
waxcylinder
Post by waxcylinder » Tue Nov 22, 2011 12:46 pm
Does this tutorial from the 1.3 manual help at all: http://manual.audacityteam.org/man/Reco ... turntables
Most of the information applies to USB cassette decks as wella s USB turntables.
waxcylinder
Post by waxcylinder » Tue Nov 22, 2011 12:50 pm
Poppy1 wrote: There is now an error message
Poppy1
This article that I have been working on regarding the resolution to this particular message may help too: http://manual.audacityteam.org/man/User ... und_device
It's not properly published yet as we haven't decided whether it should be in the manual or the Wiki
