exporting file as .wav error
cvassill
Post by cvassill » Wed Nov 02, 2011 6:45 pm
I'd like to transfer my edited songs to another computer, so I've been trying to save my songs as ".wav". This is what I've tried so far:
File --> Export... --> save --> [a Warning comes up: "You are about to save a WAV file with the name...Normally these files end in ".wav", and some progrms will not open files with nonstandard extensions. Are you sure you want to save the file under this name?" --> Yes --> [Edit Metadata pops up] "Ok" --> ***then it doesn't let me save the file and another message comes up saying "Cannot export audio to /Volumes/Audacity 1.313/Audacity/{song title}"
Help, Please! I must have these songs ready by the end of this week.
waxcylinder
Re: exporting file as .wav error
Post by waxcylinder » Wed Nov 02, 2011 6:55 pm
just save it as the filename - Audacity will add the .wav extension for you.
What you are trying to get Audacity to do is to export a file caled <file_name>.WAV.WAV - which is why it is warning you)
Post by steve » Wed Nov 02, 2011 9:15 pm
Use only letters, numbers, space, hyphen and underscore in file names. These are safe characters to use for file names. Depending on the operating system, other characters can cause problems.
