I need help playing MOGG files.
Frozen_Memories
Hello guys, I just started using this program to open MOGG files but for some reason whenever I try to put it in the program it only makes a 1-2 second screeching sound. I'm really confused right now. Any help would be appreciated.
Re: I need help playing MOGG files.
Upgrade to Audacity 1.3 and then install the FFMpeg software from the same web site.
You can put both versions of Audacity on your machine.
Audacity tries to open up highly compressed sound files whether it understands them or not. The screech is the difference between the natural duration of the file and the percent compression. Two to one data compression will fly by twice as fast.
Frozen_Memories
Thanks, I tried what you said but I keep getting an error message that says that Audacity doesn't recognize the file and that I should try the "Import Raw" option. I tried it but I kept getting the screeching sound.
Try changing the file extension to .ogg
ParadiseReaper
And what would he need to do if he already did that. (Sorry if I'm calling you a male when you're a female, I'm just being that person.)steve wrote:Try changing the file extension to .ogg
He/she probably hasn't.ParadiseReaper wrote:And what would he need to do if he already did that
How do you know what kind of file it is, and does it play in anything else?
ParadiseReaper
Actually, you provide a very valid point there.steve wrote:He/she probably hasn't.ParadiseReaper wrote:And what would he need to do if he already did that
