I work on an audio drama and am seeing an odd problem as I'm doing post-production on the show. I'm sure it hasn't always been there, but it has been popping up a lot lately: Basically, a scene of the show consists of several tracks that are recorded in mono. Once outtakes are removed, sound effects added, etc, I set each track to be either left channel, panned 30% right or right channel, panned 30% left and export it all to a single mp3. This used to result in a nicely balanced scene. However, now when I do it the tracks end up 100% left or right, regardless of the panning. Is this a bug in audacity or am I just not getting something? One possible other factor: I honestly don't remember if this is the case with the files I'm working on now, but in a couple of cases, for reasons I'm unsure of, the raw recordings I was handed were stereo instead of mono. Perhaps stupidly, instead of squishing them down into one track, I simply split the tracks and deleted one of them, then set it to mono. My understanding of the technical bits behind this is not great (as you can probably tell), but I'm guessing this could explain the issue I'm having. If that's it, can someone suggest a workaround? If not, what else might be going on? It would mean a whole lot of work to have to start over.
Thanks!
