Trouble recording from DJ controller
DJBANGBANG26
Post by DJBANGBANG26 » Fri Oct 28, 2011 3:15 am
I CAN NOT SETUP UP MY AUDACITY TO RECORD FROM MY DJ CONTOLLER TO THE AUDACITY WHICH IS LOCATED ON MY PC... I HAVE WATCHED YOUTUBE VIDS.. HELP!! CAN YOU PLEASE WALK ME THROUGH THE STEPS :roll:???!!
Moderator note: please do not SHOUT - it is considered bad netiquette on most web-forums, and is harder to read. And also please do not hijack existing threads, start a new topic unless your topic is exactly the same as the original post. I have split it off for you into its own thread.
Re: Trouble recording from DJ controller
Post by Gale Andrews » Fri Oct 28, 2011 9:09 pm
If you would like help, please tell us:
  • what version of Windows you are on (for example, XP or Vista)
  • exactly what three-section version number of Audacity you are using (for example, 1.2.6 as found at Help > About Audacity)
  • the make and model number of the DJ controller and how it connects to the computer .
If it is a MIDI controller, Audacity does not support MIDI control surfaces.
