Recommended Noise Removal levels
countryfan_nt
Post by countryfan_nt » Fri Oct 28, 2011 12:03 am
Greetings friends,
Would you please advise me what are your favorite and preferred levels for Noise removal?
It is for a spoken podcast (no music).
Thanks a lot in advance!
Noise Reduction (dB):
Sensitivity (dB):
Frequency Smoothing:
Attack/decay time:
Thank you so much in advance, for your time, experience and kind support!
Re: Recommended Noise Removal levels
Post by kozikowski » Fri Oct 28, 2011 12:37 am
It doesn't work like that. These control are all sliders because they change with the show and there are a very broad range of adjustments.
We've also found that "noise" is an interesting concept. A Metrobus starting up outside your window, leaving a TV on in the background, a dog barking and room echoes are not noise. If you have any of those, they're now performers in your show.
Is there a sample of your show somewhere we can listen to and see what you're doing?
What are you trying to fix -- in words.
