Is there a way to filter out the sound of an inhalation?
Hi All:
First time posting, as I couldn't find this in previous posts, and I am not sure what to look for anyway...
I am doing podcasts and narrations, using Audacity 1.3 on an iMac 24". I am using an Electro Voice 320, a PreSounus AudioBox 22vsl, and of course, Audacity. I am getting some great recordings, but i am also getting the intake breaths when reading...
Is there a filter (or technique short of manually doing it) to remove the 'breath' sounds that I hear when inhaling? I try to turn my head away from the mic, and still hear them. I am manually going through each recording to add silence by selecting the sections of the recording and hitting the Ctrl L command, but this is very time consuming.
I have tried the 'noise removal' filter, and it removes the frequencies from the whole recording and creates a 'canned' sound that is definitely not usable on the whole recording. Short of selecting each breathing pause, and adding silence, I don't know a way to automate this....
Attached is a snip of what i am referring to. Some are much more noticeable than this one, but this is what I want to remove in general.
Many thanks for the advice.
Mark
Mark
- Attachments
- Archive.zip
- (977.46 KiB) Downloaded 117 times
Re: Is there a way to filter out the sound of an inhalation?
Like this?
I need to collect all the settings.
- Attachments
- BreathingNoisePatched.flac
- (265.63 KiB) Downloaded 148 times
I applied Noise Gate which slices off any sounds quieter than a certain value.
Level Reduction -20
Gate Threshold -40
Attack 250
Using the drop-down menu for the track (left), Waveform dB. That will make the gasps much more visible. Pick the highest blue wave during the gasps and that's the threshold -- or slightly above.
Reduction is pretty self explanatory. 6dB is only half. 20dB is half multiplied more than three times.
Attack keeps the tool from cutting off syllables.
Enjoy,
Level Reduction -20
Gate Threshold -40
Attack 250
Enjoy,
YES like that!
Thanks for the help! I will try it also on my more audible breathing and see of that takes away the quieter parts of the rest of the reading.
However, it is a new tool I had not tried yet... Many Thanks Koz!
Mark
Mark
Uhhh, I have a TON of Audacity plug in effects posted here, but I don't see noise gate. Any idea where I can buy/download the plug in?
Or is it somewhere else in the program?
Mark
Mark
I think I fond it: noisegate.ny
Many Thanks!
Many Thanks!
The latest (and recommended) version of noisegate.ny is here: http://wiki.audacityteam.org/wiki/Nyqui ... Noise_GateMarkEMark wrote:I think I fond it: noisegate.ny
The thing does work by sound level, so if your gasping gets too loud, you may start to sheer off parts of the speech -- not be able to separate them.
billw58
No-one has yet mentioned microphone technique ...
If you are hearing breath intakes, perhaps the mic is too close to your mouth? Perhaps you are speaking too quietly?
-- Bill
-- Bill
I was going to go there, but the dialog portion sounded pretty good with no other distortions or damage.
It did sound, however, like the poster is a fifteen pack a day smoker (gasp, wheeze).
