Audacity won't let me select between whole numbers?!
Swwly
Post by Swwly » Thu Oct 20, 2011 10:52 pm
Hi,
I'm trying to make selections on a track, and it seems as though the selection tool will only let me select points in the track where there is a whole number at the top of the time line. (for example, If I'm zoomed out so that I can see the time line in seconds, I can only select on the 1, 2, 3 etc second points, I can't place my selection at 3.4 or 3.5. This is very frustrating and makes it incredibly hard to make specific tweaks. Is there a way to change this???
Thanks!
Sarah
Re: Audacity won't let me select between whole numbers?!
Post by Gale Andrews » Thu Oct 20, 2011 11:10 pm
Swwly wrote: I'm trying to make selections on a track, and it seems as though the selection tool will only let me select points in the track where there is a whole number at the top of the time line. (for example, If I'm zoomed out so that I can see the time line in seconds, I can only select on the 1, 2, 3 etc second points, I can't place my selection at 3.4 or 3.5. This is very frustrating and makes it incredibly hard to make specific tweaks. Is there a way to change this???
Turn off Snap To in Selection Toolbar:
http://manual.audacityteam.org/man/FAQ:Editing#snap
Swwly
Post by Swwly » Thu Oct 20, 2011 11:10 pm
Bah Nevermind Sorry just realized I had the snap to option checked and that's what was causing it. Grrrrr
