.4 Seconds
Zeebob24
.4 Seconds
Post by Zeebob24 » Thu Oct 20, 2011 3:03 am
I imported a song that is five minutes long, but it imports it in a timeline of .4 seconds. Is there any way I can make it play in its correct time?
waxcylinder
Re: .4 Seconds
Post by waxcylinder » Thu Oct 20, 2011 9:05 am
You are almost certainly trying to import a file type that Audacity does not support. Audacity Supports WAV, MP3, OGG and FLAC & MP2 in 1.3.
The screech is Audacity 1.2's inelegant way of telling you that it can't handle the file type you've given it - in 1.3.x a more appropriate and informative error message appears.
If this is the case you have two basic options:
1. find and use some converter software to convert your file to a type that Audacity supports
2. play the file in any music software that supports that particular file format and record it in Audacity.
steve wrote:There's a free program called SUPER by erightsoft that can convert most media file types. If you can convert the files to WAV files that should fix the problem.
