Tempo Analyzer?
Tempo Analyzer?
I have Audacity 1.3. I notice there is a "change" tempo feature. I was wondering if Audacity 1.3 can analyze and/or determine what the B.P.M. of existing track is?
Re: Tempo Analyzer?
Analyze > Beatfinder?
Audacity 1.2 isn't supported any more, so if you can't find these tools, you should upgrade to Audacity 1.3
Audacity 1.2 is very old and no longer supported,
patched, corrected, or updated. Audacity 1.2 can
be unstable on newer computers.
Download and install the latest Audacity 1.3 from here...
You can install both audacity 1.2 and Audacity 1.3 on
the same computer, but only use one at a time.
Audacity 1.2 will not open projects made on Audacity 1.3.
If you use MP3 or some of the more modern audio
compression formats, get Lame and FFMpeg software
from the same web site. Do not use older software
or software from other web sites, even though they
may have the same names.
Re: Tempo Analyzer?
Don't need a beat finder. I've got a click track for that. I want to know what the BPM of the track is.
Re: Tempo Analyzer?
Select 30 seconds of the track.
Press Play.
Count the number of beats.
Double that number.
Press Play.
Double that number.
Re: Tempo Analyzer?
ughhh.........if you don't have something intelligent to offer on this topic please ...don't.
thanks,
PHIL
thanks,
PHIL
Re: Tempo Analyzer?
What don't you like about the answer? In what way does it not suit your requirements?
