Clipfix disappeared
benni
Clipfix disappeared
Post by benni » Wed Oct 12, 2011 8:15 pm
What am I missing? I don't seem to have the Clip Fix plug in that there's a lot of discussion about on this forum.
I'm running 1.3.3 on MacOS 10.6.8. I don't see it in the effect panel but I thought it was packaged with this version. Am I looking in the wrong place?
bgravato
Re: Clipfix disappeared
Post by bgravato » Wed Oct 12, 2011 10:01 pm
benni wrote:What am I missing? I don't seem to have the Clip Fix plug in that there's a lot of discussion about on this forum.
First, you're posting on the wrong section of the forum... You posted on a thread on the Linux section of this forum, while you're on Mac, so you're problem is probably not the same that was being discussed on this thread.
Moderator note - moved to OS X forum
Second, you're using a very old version of Audacity. You should upgrade to the latest 1.3.13. You can get the mac version from here: http://audacityteam.org/download/beta_mac
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
