What's The Easiest Way To Crossfade Two Subsequent Tracks?
Son of Spam
Post by Son of Spam » Sat Aug 30, 2008 9:42 pm
The first song ends cold and the second starts cold.
I want to combine the respective ending and start of the two songs, with maybe a half-second of crossfade in between.
How can I do that?
Re: What's The Easiest Way To Crossfade Two Subsequent Track
Post by Gale Andrews » Sun Aug 31, 2008 5:48 am
Put the two songs on separate tracks and use Time Shift Tool (F5) to align the end of one with a point (say) three seconds into the start of the other. Then use envelope tool (F2) separately on each track to make a smooth fade out where the one track is ending and a smooth fade in where the other is starting. Playing or exporting will mix the two tracks together, and if you get the fade right the songs will blend into each other seamlessly..
