Changing a track
JGHopkins
Changing a track
Post by JGHopkins » Sat Oct 08, 2011 12:25 am
I've never done any track editing before, so I'm wondering if what I wanna do is even possible
I wanna take out the background vocal from this song
http://www.youtube.com/watch?v=SapoWXsVeQw
the part where it says dino thunder.
and somehow mix the song with either this one
or at least pieces of it....cause they horrible just laid over it :P
http://www.youtube.com/watch?v=4EomZwIVa_E
or this one
http://www.youtube.com/watch?v=5ilrSP_K ... e=youtu.be
is that actually possible or just a pipe dream?
Re: Changing a track
Post by kozikowski » Sat Oct 08, 2011 12:43 am
You should probably try to separate the vocals and the instruments before you go too much further. If that step fails, then you have no show no matter what else happens.
Vocal Isolation is not a standard tool in Audacity. You might try ...
-Voice Trap
http://www.cloneensemble.com/vt_main.htm
--Extra Boy
http://www.kvraudio.com/get/1651.html
--Kn0ck0ut
http://www.freewebs.com/st3pan0va/
But even before you do that, you should stop using Audacity 1.2.
Audacity 1.2 is very old and no longer supported,
patched, corrected, or updated. Audacity 1.2 can
be unstable on newer computers.
Download and install the latest Audacity 1.3 from here...
You can install both audacity 1.2 and Audacity 1.3 on
the same computer, but only use one at a time.
Audacity 1.2 will not open projects made on Audacity 1.3.
If you use MP3 or some of the more modern audio
compression formats, get Lame and FFMpeg software
from the same web site. Do not use older software
or software from other web sites, even though they
may have the same names.
JGHopkins
Post by JGHopkins » Sat Oct 08, 2011 12:45 am
ok cool I do have 1.3
I'll download one of the others and play around with it :)
if anyone wants to offer help I would not be opposed lol
