Analysis, spectrum
claude.legros
Analysis, spectrum
Post by claude.legros » Thu Oct 06, 2011 4:15 pm
Is it possible to reduce frequency zone in spectrum i.e. amplitude vs frequancy. For exemple, reduce to 8000Hz?
Thnaks
Re: Analysis, spectrum
Post by kozikowski » Thu Oct 06, 2011 6:34 pm
Analyze > Plot Spectrum will always expand to display everything it thinks in in your show -- or your selection.
You can restrict the show by applying filters.
Effects > Low Pass Filter > 8000
That will make a new show that gracefully dies around 8000 Hz. If you analyze the new show, the display should show significant dip or rolloff around there. It will not do a "brick wall" drop. You can force tools to do that, but the music may be damaged.
