No sound
muiden
No sound
Post by muiden » Sat Aug 30, 2008 10:22 am
Hi, I just installed Audacity as I want to finaly copy my old vinyl records on CD
For this I use a Lenco L3866 USB turntable and linked this to my IBM PC.
Installing the Audacity software (with the turntable already switched on and the USB cable in my computer)
I noticed that where the instruction manual tells me to press Micophone and change it into Stereo Mix,
there is no data/words whatsoever in this little box.
However I managed to get things working, I recorded my first vinyl, and exported it to both a .wav and a .mp3
file (using LAME)
And now I have the following problem/error.
If I want to play either one of these files with Windows media player, I hear no sound at all!
Where if I open Audacity, load the file and use Audacity to play, I can hear sound.
Probably an easy/stupid setting issue, but I tried all kind of settings and cound not get it working.
Plse does anyone know how to solve ??
Thanks Muiden
Re: No sound
Post by steve » Wed Sep 03, 2008 10:01 pm
Export as "16 bit 44100Hz Microsoft PCM WAV"
In Audacity 1.3.x you can do this through the Export dialogue - for Audacity 1.2.x, check the on-line manual for details.
waxcylinder
Re: No sound
Post by waxcylinder » Sun Sep 07, 2008 4:59 pm
muiden wrote: I noticed that where the instruction manual tells me to press Micophone and change it into Stereo Mix,
This is expected behaviour - when you plug in a USB TT like this Audacity hands over complete control over the sound services to the USB device, so no options are available in the input selector dropdown - the input slider in Audacity is likely to be inoperable too, for the same reason.
