steve wrote:IF you can open it. A 12 hour CD quality file will be about 7 GB.
Of course. I did say SS had a 2GB limit. Nevertheless, for an app of this type to still work, and work well, after a decade and so many OS changes is remarkable.
steve wrote:Here's a quick way to do the same in Audacity
Yes; but, splits are not, as you say, markers. You can't move them; you can't
use them for Export Multiple; unless I'm mistaken, you can't convert audio between them into regions; etc.
steve wrote:An even quicker way if the selection does not need to be exact
But that's precisely my point -- that, in Audacity, it is difficult to make
exact selections.
steve wrote:My preferred method for making an exact selection
And what do you do if you want to keep two non-adjacent 15 min clips from the 12 hrs file? (I assume Audacity is well engineered, and keeping undo alive while deleting 11.5 hrs from a 12 hrs file does not involve too much disk work.) Or if you change your mind, and want to extend the selection just a few samples?
steve wrote:often I can complete the job in Audacity faster than it takes for Adobe Audition to launch. The benefits of familiarity with a program are easy to underestimate.
Your point is well taken. But my problem is not that Audacity does things differently, but that it doesn't have the tools to do things right. The first basic task of a GUI audio editor is to open and display the waveform. The second is to allow for convenient and precise selection of the portion of the waveform on which other tasks are to be performed.
Say I digitised an old tape. I open it in Audacity to process it for CD. I need to mark different segments, on which to apply different effects, and then export them. Quality work demands precise selections. I could use Split -- but I can't move a split, and I can't convert splits to labels, and (somewhat counterintuively, I'd say) I can't actually split (export multiple) the file by splits. I can use point labels, but I can't select quickly between them. I can use region labels, but I can only do it by dragging, which is inaccurate. Sound Studio does all that easily, and with just one type of marker instead of three.
As a result, I use Audacity almost exclusively for one purpose -- split files > 2GB into segments Sound Studio can open (and that, only because I don't want to bother to learn the sox syntax). Audacity probably normalizes thrice as fast as Sound Studio; but that is as nothing compared to the time wasted (and frustration experienced) in trying to make an accurate selection.
