Headphones no longer cut out speaker.
philfox
Post by philfox » Tue Oct 04, 2011 8:15 pm
I have installed Audacity today, and now, when I plug in my headphones, sound still comes out of my laptop speakers, which didn't happen before. It is an Acer Aspire 5551 running Windows 7 Home Premium. I have tried changing various settings in Control Panel > Sound, but cannot sort this out.
Any help would be appreciated.
Re: Headphones no longer cut out speaker.
Post by kozikowski » Tue Oct 04, 2011 10:06 pm
Audacity Preferences > Recording > [ ]Overdub..., [ ]Hardware..., [ ]Software..., should be all be unchecked. Restart Audacity.
Post by kozikowski » Tue Oct 04, 2011 10:10 pm
If it's still behaving badly, it has to be in the laptop settings. Does the laptop have sound settings or control panels different from Windows?
That's a very odd combination. That's usually a hardware switch, not software. Some computers use software routing and it's possible to get those confused. When you run Audacity, what output device does it say it's using?
philfox
Post by philfox » Thu Oct 06, 2011 8:29 am
I'm not quite sure what you mean by 'Does the laptop have sound settings or control panels different from Windows?'
When I go into Control Panel and Sound, I get the window showing tabs 'Playback' 'Recording' 'Sounds' and 'Communications'.
As far as my Audacity settings are concerned, I am currently showing the following setting in Output Device 'Speakers (Realtek High Defini'. The only other choice is Microsoft Sound Mapper - Output'
Thanks
Post by steve » Thu Oct 06, 2011 10:56 am
philfox wrote:I'm not quite sure what you mean by 'Does the laptop have sound settings or control panels different from Windows?'
Have a look at the little icons near the Time/Date. (some of the icons may be hidden).
There should be at least one "Loudspeaker" icon. There may be two. Check thoroughly the available options by right and left clicking on those icons.
It's quite common for there to be two different loudspeaker icons. One of which is the normal Windows settings and the other which is a custom sound setting control panel for your sound card. Some of the controls in one will be the same as the other and some will be different. Sorry I can't be more specific but it's a bit of a mess really and different machines have different settings in different place.
philfox
Post by philfox » Sat Oct 08, 2011 9:40 am
I have one speaker icon.
When I right click on icon and select:
1. Volume mixer, there are 3 controls - device Speakers, Applications, System Sounds, and Plugin Container for Firefox
2. Playback devices, there are 2 devices showing - Realtek HDMI Output (Properties, Not Plugged in, but enabled), and Speakers (Selected and enabled, Controller information - Realtek High Definition Audio; Jack Information, LR ATAPI Internal ATAPI Jack)
Post by steve » Sat Oct 08, 2011 11:33 am
Have a look in the Windows Control Panel (Classic View) and see if there is an icon for Realtek in there.
philfox
Post by philfox » Sat Oct 08, 2011 7:07 pm
There is one called 'Realtek HD Audio manager'
Post by Gale Andrews » Sun Oct 09, 2011 12:00 am
philfox wrote:There is one called 'Realtek HD Audio manager'
So look in there on the playback side for an image of the headphones jack. There may be a switch to control what it does that is set to "Front speaker out" or similar. Set it to "Headphone". "Front speaker out" is usually intended as a way to play through both the headphones and the speakers at the same time.
philfox
Post by philfox » Sun Oct 09, 2011 9:18 am
I've come to the conclusion that this is indeed a hardware problem.
In the Realtek HD Audio Manager, under 'Analog', there is a red icon for the mic in socket, and a green icon representing the headphones socket.
If I plug my earphones in to mic socket, the red icon 'lights up', but when I plug them into headphones socket, green icon stays 'unlit'.
Thanks for all the help and advice.
